Marlin response too early
June 12, 2015 10:57AM
*Moved from General*
The issue I am experiencing is that Octoprint sends Gcodes to RAMPS(Marlin) and RAMPS responses with ok, however, before it actually having moved its motor to the position.
So what actually happens is only few of the Gcode sent by Octoprint being actualized to the machine. Although I made an STL file with star shape, it makes some random shape or even completely ignores XY movement and only raise extruder head every 2 seconds which is insane. The estimated print time is 3hours according to CURA, but RAMPS, which experiences almost instantenous response from RAMPS, estimates its finish time to 10 minutes!
Here is the terminal log from Octoprint :
Send: N6725 G0 F600 X205.675 Y141.513*78
Recv: ok
Send: N6726 G1 F1200 X207.931 Y139.258 E124.31224*57
Recv: ok
Send: N6727 G0 F600 X208.769 Y139.833*77
Recv: ok
Send: N6728 G1 F1200 X207.089 Y141.513 E124.31378*50
Recv: ok
Send: N6729 G0 F600 X208.503 Y141.513*77
Recv: ok
Send: N6730 G1 F1200 X210.027 Y140.696 E124.31480*54
Recv: ok
Send: N6731 G1 X209.918 Y141.513 E124.31533*89
it would have been much more descriptive if I could configure octoprint to print out timestamps, but I can tell you that this much log happened in less than 2 seconds.
Our printer in fact isn't conventional - we are extruding chocolate out of cylinder, so we have some few irregularities on CURA settings. Since we are extruding molten chocolate out of cylinder, we set filament diameter to 42mm and layer thickness to 1mm (both causing warning message), although I don't really think this is the source of error.
Did anyone experience same problem as me when using octoprint + marlin? I would appreciate it if you could share your solution. I am also attaching my configuration.h
Thanks!
Edited 2 time(s). Last edit at 06/12/2015 10:59AM by totorovirus.
open | download - Configuration.h (35 KB)
Re: Marlin response too early
June 12, 2015 11:21AM
It is entirely normal for 3D printer firmware to acknowledge commands before they have been fully actioned. If it didn't, the machine wouldn't be able to do lookahead, which would result in very slow and low-quality prints. What should happen is that once the lookahead queue is full, the firmware only sends OK in response to a new command when it has room in the lookahead queue for it.
Do you see the same problem when you use e.g. Pronterface to print the file, instead of Octoprint?
June 12, 2015 11:52AM
Did you mix up filament diameter with nozzle diameter?
Filament dia is more important in relation to extruder-steps, but you seem to have a problem with x/y movement and it´s calculated based on nozzle dia.
-Olaf
Edited 1 time(s). Last edit at 06/12/2015 11:54AM by o_lampe.
June 13, 2015 12:49AM
Here is the nozzle and diameter setting in CURA.
June 13, 2015 12:51AM
dc42
I'll try it with Pronterface though I don't really think the driver caused the problem.
June 13, 2015 05:16AM
42mm diameter filament? You're sure it's not 3.0?
June 13, 2015 12:23PM
Note they said this is extruding chocolate . . . this isn't your Mother's RepRap . . .
- Tim
June 14, 2015 08:12PM
But still, 42mm diameter = 1.68".
From Configuration.h
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,1600,266.67} // default steps per unit for Ultimaker
So 1 extruder step gives pi*42*42/266.67 = 20.8 cubic mm of chocolate = 6.6mm of extruded chocolate
This seems like an order of magnitude (or two) out.
June 15, 2015 03:02AM
frankvdh
It is a geared stepper for sure. Paste extrusion often use a leadscrew design.
Did you mix up radius and diameter?
"Pi/4 D²" would be right grinning smiley
-Olaf
June 15, 2015 03:28PM
Doh! You're right, Olaf.
Correctly,
1 extruder step gives pi*21*21/266.67 = 5.19 cubic mm of chocolate = 6.6mm of extruded chocolate
Which still seems an order of magnitude or two out.
June 16, 2015 11:16AM
frankvdh
Correctly,
Looks better! grinning smiley
But could you please draw a mental picture how a steppermotor would directly drive such a syringe/paste extruder?
There has to be an ( unknown for us ) gear-ratio between stepper and syringe, right? smiling smiley
@totorovirus Does the problem still exist?
June 16, 2015 03:15PM
I haven't even considered gears and so on. I believe that the mechanical side is irrelevant... the steps/mm in Configuration.h gives the relationship between the stepper motor steps and the feed rate into the hotend.
June 18, 2015 03:40AM
SOLVED
the software endstop caused the problem. whenever the movement was set to out of bounds, it completely ignored the movement.
maybe printing warning message rather than just sending recv: ok would be a better.
Thanks for your support
Edited 1 time(s). Last edit at 06/18/2015 03:40AM by totorovirus.
June 18, 2015 06:15AM
Good to hear, it is solved... where is my chocolate bunny? winking smiley
@frank
Now I got it, you were talking about 6.6mm / step...I caculated, my extruder would produce a track of ~19mm per 1mm filament (1.75/ 0.4 nozzle ), so I thought 6.6mm is OK eye rolling smiley
