1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 22, 2015 07:54PM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 22, 2015 10:51PM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 23, 2015 06:45AM |
. If I limit the movement of the arm up to the singularity (on one side only), the printer I designed is basically a Morgan without the assisting arms (single arm scara). Whatever Morgan is running onto I basically can use. As far as I know Morgan first started with Mega/Ramps1.4 now they use Smoothieware.|
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 27, 2015 03:31PM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 28, 2015 05:55AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 28, 2015 09:02AM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 28, 2015 09:45AM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? June 28, 2015 11:16AM |
Nicholas.Seward
Re: Ideas for the next Wally.
Postby Nicholas Seward » Wed Apr 15, 2015 3:23 am
Here are the kinematics for all the cases. They are all pretty simple and as I said in the last post the effects of miscalibration all look about the same.
Variable Definitions
L=length of arm
ma=mechanical advantage (This is what could be miscalibrated if you drive the machine with string.)
(r,theta)=polar coordinates
(a,b)=stepper positions
Inverse Kinematics
Case 1:
a=(theta-acos(r/(2*L)))*ma;
b=(theta+acos(r/(2*L)))*ma;
Forward Kinematics (Needed for end stop detection.)
Case 1:
r=2*L*cos((b-a)/(2*ma));
theta=(a+b)/(2*ma);
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 14, 2015 09:45AM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 16, 2015 07:02PM |
realthor
@DC42: Was this info useful in any way? What RepRapFirmware are you talking about exactly?
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 17, 2015 01:53PM |
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 18, 2015 06:24AM |
realthor
The git webpage of the scara branch sais " This branch is 10 commits ahead, 224 commits behind master".
realthor
1) Can I just copy the configtool from Master to scara branch?
realthor
2) The board I am trying to use is a Sanguinolulu that has its chip changed to an Atmega1284p yet I don't see anywhere any file that would suggest this chip is covered.
#if ! ( defined (__AVR_ATmega644P__) || defined (__AVR_ATmega644PA__) ) #error Sanguinololu has a 644P/644PA! set your cpu type in Makefile! #endifby this:
#ifndef __AVR_ATmega644__
#ifndef __AVR_ATmega644P__
#ifndef __AVR_ATmega1284P__
#error Sanguinololu has an ATmega 644, 644P or 1284P. Set your CPU type in the \
Makefile or select your board in the Arduino IDE!
#endif
#endif
#endif
realthor
How should I proceed to manage to compile a firmware and upload to the board?
sudo apt-get install geany make avrdude gcc-avr avr-libc cp config.sanguinololu-v1.2.h config.h cp Makefile-AVR Makefilethen to use geany to adjust the Makefile (lots of comments in there on how to do this), to build and to upload:
geany Makefile # for editing, then save make make program
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 18, 2015 12:24PM |
config.h:382:58: error: ‘THERMISTOR_BED’ undeclared here (not in a function)
DEFINE_TEMP_SENSOR(bed, TT_THERMISTOR, AIO6, THERMISTOR_BED)
temp.c:54:102: note: in definition of macro ‘DEFINE_TEMP_SENSOR’
#define DEFINE_TEMP_SENSOR(name, type, pin, additional) { (type), (pin ## _ADC), (HEATER_ ## name), (additional) },
Re: 1-Arm SCARA support in firmware? Which one? Smoothieware best for SCARA? July 18, 2015 01:03PM |
// Names for our tables, so you can use them in config.h. // Table numbering starts at 0. #define THERMISTOR_EXTRUDER 0 #define THERMISTOR_BED 0 // <-- added this
dda.c: In function ‘dda_create’:
dda.c:226:5: error: ‘DDA’ has no member named ‘delta_um’
dda->delta_um[X] = abs32(tmp_steps_x - startpoint_steps.axis[X]);
dda.c:228:5: error: ‘DDA’ has no member named ‘delta_um’
dda->delta_um[Y]= abs32(tmp_steps_y - startpoint_steps.axis[Y]);
Traumflug
theothermike
dda.c:226: error: 'DDA' has no member named 'delta_um'
dda.c:228: error: 'DDA' has no member named 'delta_um'
Try with LOOKAHEAD defined as well. It's in config.h.
. I get the same behavior of having the motors hum but no movement just as theothermike. I tested also the scara fork of Marlin that vitaminrad has on git and that moved the motors as instructed. Something is not right with this branch and I think this has to be corrected, because as far as I can see on the forums, more and more people are experimenting with scara bots.
