Dual extrusion from LCD (RAMPS1.4 - Marlin 1.0.2)
Posted by SergioMC
July 22, 2015 04:13AM
Hi I am working with dual extrusion set-up.
I found from LCD you can't change active extruder, so I mod Marlin to allow manual extrusion (E0 or E1) from LCD.
Dual Extrusion.
Marlin 1.0.2 Modification for change active extruder from LCD.
It`s very simple.
Open Marlin on Arduino IDE.
Search UltraLCD.h
Add this two lines:
MENU_ITEM(gcode, "Activar E0", PSTR("T0"));
MENU_ITEM(gcode, "Activar E1", PSTR("T1"));
I added before this line:
MENU_ITEM(gcode, MSG_DISABLE_STEPPERS, PSTR("M84"));
After this mod you can choose active extruder E0 or E1 and move it from Move Menu>1 mm (0.1 mm)>Extruder
I love OpenSource.
I hope you find this useful.
Google+Post
Re: Dual extrusion from LCD (RAMPS1.4 - Marlin 1.0.2)
July 22, 2015 12:33PM
I find it very useful! thumbs up
Now, if I only find a way to retract faster.
It takes forever to change filament with a 500mm Bowden tube sad smiley
-Olaf
My only solution so far is a hand written g-code that is permanently on my SD-card.
July 23, 2015 02:38AM
Maybe
MENU_ITEM(gcode, "unload filament", PSTR("your gcode for extract filament"));
MENU_ITEM(gcode, "load filament", PSTR("your gcode for load filament "));
This is not tested so be careful.
Keep your finger on power button while testing changes.
