Adjust the Z while printimg the first layer
October 12, 2015 07:32PM
The Z of my prusa printer is changing a lot with different bed temperatures. It would be great to mannualy adjust the Z (with the lcd knob) while printing the first layer. Is this possible?
(prusa i3 running marlin)
Re: Adjust the Z while printimg the first layer
October 13, 2015 01:09AM
I know this problem, too. But my solution is to simply finetune the Z-level of my i3s manually by turning the Z-couplings slightly while the skirt of the first layer is printing. For this, you must make sure that the Z-motors are disabled when not moving (#define DISABLE_Z true) so that the Z-motors rotate easily when not moving between layers. It takes a little practice to rotate both couplings in the right direction until the extrusion width is what you want it to be. But once you get the hang of it, it's really easy and the result is as good as using ABL - IMHO even better, because I can adjust the first layer height for each print individually (some objects need more, some less "pushing").
October 13, 2015 02:38AM
You can enable babystepping. Marlin has this feature. With that you can easy adjust Z while printing the first layer.
October 13, 2015 07:45AM
Was going to mention baby stepping also.
I did not know you could disable the Z steppers between Z moves. I guess that does make it easy to hand-turn the couplings.
October 14, 2015 03:09AM
That's it! Babystepping is enabled and working very well.
Thanks.
October 19, 2015 09:45AM
I have to look into this because I have nothing but issues with my Z height.
The bed has been leveled with a dial indicator to about .001" all around. My problem is that I can set the Z height before a print perfect but once the print is started and re homes the Z can be off by quite a bit. Im not sure whats up but its REAL annoying that I can print perfect 50% of the time and the other I have to reset the Z height before I print.
October 22, 2015 09:35AM
Sounds like a heat-warp issue, or a loose frame.
October 22, 2015 12:21PM
Simple solution: don't re-home the Z axis at the start of a print. Remove the G28 command from your slicer start gcode, or change it to G28 X0 Y0.. Either set the Z=0 height manually before starting a print, or use a Z probe and a G30 command in your start gcode to find where Z=0 is.
