DC42 firmware, multiple topics after first run October 15, 2015 03:03AM |
Re: DC42 firmware, multiple topics after first run October 15, 2015 04:21AM |
shadowphile
First of all, I have not changed any of your code from before when I was running the duet on my old mini kossel. The version I was using ok before and on the current setup is 1.09g-rc1-dc42 (2015-08-22).
shadowphile
[*] My scale is way off, like 5%. 68mm prints as 72mm. Since autocal does all the work I'm not sure what is wrong. The only inputs I have are the rod lengths and the bed diameter and the rod lengths are super accurate. (of course the steppers counts for the motors are good)
shadowphile
[*] The heater keeps turning off after I do an autocal run.
shadowphile
[*] I can't find the reference about how to calculate the H parameter for the z probing. Please provide it as an equation, ie H=center probe-spot probe.
shadowphile
[*] Autocal is getting about .1 mean dev, with spots that are as large as .25mm difference (using the H values as calculated above). If I reverse the sign of the H values, I get more like .16 mean dev.
I know this is a reflection of the mechanical accuracy; is this a reasonable number for this size of system ie errors are within measurable limits for a system this size. It can be difficult to measure distances and squarenesses with just sticks and rulers, since I don't have a humongous digital calipers.
shadowphile
[*] The custom effector platform and carriages have 80mm rod spacing. It probably is magnifying dimensional errors although it supposed to make it easier to tighten tolerances and reduce the impact of play.
shadowphile
Here are the nozzle/probe offsets as manually measured for each spot. This is what I am basing my H values on.
G1 X0 Y0 Z3 F5000 ;2.47
G1 X150 Y0 Z3 F5000 ;2.68
G1 X106 Y106 Z3 F5000 ;2.47
G1 X0 Y150 Z3 F5000 ;2.41
G1 X-100 Y106 Z3 F5000 ;2.34
G1 X-150 Y0 Z3 F5000 ;2.30
G1 X-106 Y-106 Z3 F5000 ;2.24
G1 X0 Y-145 Z3 F5000 ;2.35
G1 X106 Y-106 Z3 F5000 ;2.63
G1 X100 Y-40 Z3 F5000 ;2.46
G1 X66 Y40 Z3 F5000 ;2.40
G1 X0 Y80 Z3 F5000 ;2.51
G1 X-75 Y25 Z3 F5000 ;2.37
G1 X-60 Y-50 Z3 F5000 ;2.38
G1 X0 Y-90 Z3 F5000 ;2.28
G1 X35 Y-50 Z3 F5000 ;2.40
Re: DC42 firmware, multiple topics after first run October 15, 2015 05:44AM |
Re: DC42 firmware, multiple topics after first run October 15, 2015 06:59PM |
Re: DC42 firmware, multiple topics after first run October 16, 2015 05:48AM |
Re: DC42 firmware, multiple topics after first run October 17, 2015 04:30PM |
Re: DC42 firmware, multiple topics after first run October 18, 2015 03:40AM |
