enabled Auto-level makes entire printer move very slowly November 20, 2015 01:45AM |
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 03:22AM |
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 03:38AM |
Follow uneven bed: There is no such feature as far as I know? In any case:Quote
o_lampe
Is it configured to make the head follow an uneven bed? Then the IR sensor would be sampled a lot during any move. What if the bed is out of reach for the sensor?
Did you confuse mm/s and mm/min? Some variables like homing feedrate are in mm/min.
-Olaf
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 03:49AM |
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 04:00AM |
I don't know except the bed is so far Down the sensor gets no new information.Quote
o_lampe
How do you know the controller isn't sampling the sensor?
From what I've experienced with marlins dev firmware, they seem to focus on Cartesian printers. Deltas and coreXY are last to be supported/debugged.
Thinkyhead doesn't even have a delta to test his ABL-code :/
-Olaf
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 05:12AM |
Regarding sensor samplingQuote
o_lampe
-Olaf
Re: enabled Auto-level makes entire printer move very slowly November 20, 2015 06:24AM |
Re: enabled Auto-level makes entire printer move very slowly November 25, 2015 01:26PM |
For some reason RC just does not Work with my arduino + ramps. I tried several Vanilla installations and ended up going back to latest stable, which Works like a charm. I do not know where the error was, but I'm pretty sure it wasn't me.Quote
dc42
After running auto level and before or when moving the head around, are you setting a feed rate (F parameter in the G1 command)? The last move that the auto level procedure did may have been a Z move with a low speed, and if you send a G1 command with no F parameter after that, you will get the same low speed.
Forget that - I see that you don't even need to run the auto level operation, moves are slow already.
Are you quite sure you have copied all your configuration.h parameters across from the old to the new firmware?
Re: enabled Auto-level makes entire printer move very slowly November 26, 2015 09:26AM |
Re: enabled Auto-level makes entire printer move very slowly November 26, 2015 11:53AM |
Vanilla = From scratch = from zeroQuote
o_lampe
What do you mean with " Vanilla installations" ?
Did you try to copy&paste some configuration.h from elsewhere? That wouldn't work since a few variables got new names and different meanings/behavior.
You'd have to go through each line and knit your own config.h and config_adv.h
-Olaf
