Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 19, 2010 10:41PM |
C:\Program Files\reprap>rem reprap-host -- runs Reprap Java host code with an ap propriate classpath C:\Program Files\reprap>rem Amount of RAM to allow Java VM to use C:\Program Files\reprap>set REPRAP_RAM_SIZE=1024M C:\Program Files\reprap>rem reprap.jar file and stl file C:\Program Files\reprap>set REPRAP_DIR=C:\Program Files\Reprap C:\Program Files\reprap>rem Java3D and j3d.org libraries C:\Program Files\reprap>set JAVA_LIBRARY_DIR=C:\Program Files\Reprap C:\Program Files\reprap>rem cd so we can find the reprap-wv.stl file. Can we av oid this?? C:\Program Files\reprap>IF NOT EXIST reprap-wv.stl cd "C:\Program Files\Reprap" C:\Program Files\reprap>java -cp ".\reprap.jar;.\RXTXcomm.jar;.\j3dcore.jar;.\j3 d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3.jar;.\vecmath.jar;." -X mx1024M org/reprap/Main Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7
ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.922s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.953s/31ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.953s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.953s/0ms] ERROR: bufferQueue(): too many retries (4) sending T0 [27.953s/0ms]
21:28:59 Send >>Connecting to port: COM6 at speed 115200 21:29:00 Send >>Sending:M105 21:29:01 Send >>Received: start 21:29:03 Send >>Sending:M105 21:29:03 Send >>Received:T:307 with parameter 307 21:29:06 Send >>Sending:M105 21:29:06 Send >>Received:T:302 with parameter 302 21:29:09 Send >>Sending:M105 21:29:09 Send >>Received:T:298 with parameter 298 21:29:12 Send >>Sending:M105 21:29:12 Send >>Received:T:305 with parameter 305 21:29:15 Send >>Sending:M105 21:29:15 Send >>Received:T:312 with parameter 312 21:29:18 Send >>Sending:M105 21:29:18 Send >>Received:T:315 with parameter 315 21:29:21 Send >>Sending:M105 21:29:21 Send >>Received:T:307 with parameter 307 21:29:24 Send >>Sending:M105 21:29:24 Send >>Received:T:305 with parameter 305 21:29:27 Send >>Sending:M105 21:29:27 Send >>Received:T:293 with parameter 293 21:29:30 Send >>Sending:M105 21:29:30 Send >>Received:T:310 with parameter 310 21:29:33 Send >>Sending:M105 21:29:33 Send >>Received:T:302 with parameter 302 21:29:36 Send >>Sending:M105 21:29:36 Send >>Received:T:312 with parameter 312 21:29:39 Send >>Sending:M105 21:29:39 Send >>Received:T:302 with parameter 302 21:29:42 Send >>Sending:M105 21:29:42 Send >>Received:T:300 with parameter 300
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 23, 2010 08:28PM |
C:\Program Files\reprap>rem reprap-host -- runs Reprap Java host code with an ap propriate classpath C:\Program Files\reprap>rem Amount of RAM to allow Java VM to use C:\Program Files\reprap>set REPRAP_RAM_SIZE=1024M C:\Program Files\reprap>rem reprap.jar file and stl file C:\Program Files\reprap>set REPRAP_DIR=C:\Program Files\Reprap C:\Program Files\reprap>rem Java3D and j3d.org libraries C:\Program Files\reprap>set JAVA_LIBRARY_DIR=C:\Program Files\Reprap C:\Program Files\reprap>rem cd so we can find the reprap-wv.stl file. Can we av oid this?? C:\Program Files\reprap>IF NOT EXIST reprap-wv.stl cd "C:\Program Files\Reprap" C:\Program Files\reprap>java -cp ".\reprap.jar;.\RXTXcomm.jar;.\j3dcore.jar;.\j3 d-org-java3d-all.jar;.\j3dutils.jar;.\swing-layout-1.0.3.jar;.\vecmath.jar;." -X mx1024M org/reprap/Main Stable Library ========================================= Native lib Version = RXTX-2.1-7 Java lib Version = RXTX-2.1-7 ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:00000N0 T0 *26 [0.000s/-1285286491406ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Li ne Number is not Last Line Number+1, Last Line:0 [0.015s/15ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:1 [0.015s /0ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N0 T0 *26 [ 0.031s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Li ne Number is not Last Line Number+1, Last Line:0 [0.047s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:1 [0.062s /15ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N0 T0 *26 [ 0.078s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Li ne Number is not Last Line Number+1, Last Line:0 [0.078s/0ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:1 [0.094s /16ms] ERROR: GCodeReaderAndWriter.getETemp() - no value stored! [0.094s/0ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N1 M113 *1 [1.609s/1515ms] ERROR: GCodeReaderAndWriter.getETemp() - no value stored! [1.609s/0ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N1 M113 *1 [3.125s/1516ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Li ne Number is not Last Line Number+1, Last Line:1 [3.140s/15ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:2 [3.140s /0ms] ERROR: GCodeReaderAndWriter.getETemp() - no value stored! [3.156s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N1 M113 *1 [3.187s/31ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRaperial Error: Li ne Number is not Last Line Number+1, Last Line:1 [3.203s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Resend:2 [3.203s /0ms] ERROR: GCodeReaderAndWriter.getBTemp() - no value stored! [3.219s/16ms] ERROR: GCodeWriter.waitForResponse() - dud response from RepRap:Echo:N2 M105 *5 [4.719s/1500ms]
19:58:45 Send >>Connecting to port: COM6 at speed 115200 19:58:47 Send >>Sending:M105 19:58:48 Send >>Received: start 19:58:50 Send >>Sending:M105 19:58:50 Echo >>Echo:M105 19:58:50 Send >>Received:T:21.00 with parameter 21.00 19:58:53 Send >>Sending:M105 19:58:53 Echo >>Echo:M105 19:58:53 Send >>Received:T:21.00 with parameter 21.00 19:58:56 Send >>Sending:M105 19:58:56 Echo >>Echo:M105 19:58:56 Send >>Received:T:20.00 with parameter 20.00 19:58:59 Send >>Sending:M105 19:58:59 Echo >>Echo:M105 19:58:59 Send >>Received:T:20.00 with parameter 20.00 19:59:02 Send >>Sending:M105 19:59:02 Echo >>Echo:M105 19:59:02 Send >>Received:T:19.00 with parameter 19.00 19:59:05 Send >>Sending:M105 19:59:05 Echo >>Echo:M105
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 23, 2010 09:08PM |
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 24, 2010 04:25AM |
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 24, 2010 07:50PM |
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating September 25, 2010 07:51AM |
Re: Arduino Mega using Shapercube (joaz's) firmware, problems communicating December 13, 2010 07:39AM |
