New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 15, 2016 08:23PM |
Cookies are no longer used and settings are now stored in localStorage
Added French and Swedish translations (thanks PRouzeau and Djhg2000)
Rewrote many parts of the print status page and made the following changes:
- Improved print end detection
- Layer times are now added as hoverable dots
- Last layer time is displayed in Collected Data
- Optional webcam surveillance image can be displayed
Implemented drag&drop on the G-Code and Macro file pages
ZIP files can be uploaded (their content is unzipped via JS and each file is uploaded individually)
Configuration file can be edited (requires new rr_configfile response)
Split up JS code into model and viewmodel files
Removed Spools page (load+unload functionality can be restored via macros)
Bug fix: Removed bad JS call from the macro update function
Bug fix: Sometimes the update loop was running twice
css/defaults.css
js/jquery.autosize.js
js/jquery.autosize.min.js
js/jszip.js
js/jszip.min.js
js/interface.js (deleted)
js/model.js
js/viewmodel.js
language.xml (optional, delete this one if you don't use any translations)
reprap.htm
Version 1.09r
Changed thermocouple CS, Roland CTS/RTS and inkjet out pins
Reduced maximum thermocouple number from 4 to 2
Implemented new output stack mechanism to fix OutputBuffer bugs
Improved OutputBuffer writing performance by adding last entry pointers and added debugging facilities
Moved Dac0 definition from Platform.cpp to Pins header file
Implemented experimental thermostatic fan control and thermocouple control (thanks dnewman/dc42)
Increased code safety in Network class
Implemented new rr_configfile response in the webserver
Moved Roland RTS and CTS pins for external thermocouple SPI functionality
Moved some of the Roland definitions to the Pins header
Updated Makefiles for latest Arduino and Duet board versions
Reduced time to wait after stty handshake in Makefile from 2s to 1s
Added further safety precautions to FileData class
Implemented diagnostics for each webserver protocol handler
Added new load and unload filament macros to SD image
Other minor changes
Bug fix: M25 could cause watchdog resets when macro files were interrupted
Bug fix: Error status 1 was always reported in the diagnostics
Bug fix: rr_move always reported error code 1 on success
Arduino device tree 1.07:
- StringRef class moved to Arduino core
- Better ADC initialisation added to variant.cpp (thanks dc42)
Many thanks to dc42 for the following:
- Merged in all changes from 1.09p-alpha2
- Changed static const definitions to simple consts
- Strings are now defined via precompiler DEFINEs
- Fan value restoration now works the same way as in dc42's fork
- Merged in better output pin control
- Added several fixes to EMAC driver
- Changes for better read/write performance in HSMCI driver
- Fixed bug where the HTTP server picked up an extra command word
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 06:45AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 07:07AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 07:11AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 07:20AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 07:21AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 07:22AM |
chrishamm
That's intentional, the textarea is supposed to resize dynamically depending on its content. That's why I added js/jquery.autosize.min.js to this version. But you should be able to use the scroll wheel or touchpad to scroll up and down as well
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 16, 2016 08:12AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09q-ch January 16, 2016 08:38AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 16, 2016 08:57AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 16, 2016 09:33AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 16, 2016 12:51PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 16, 2016 03:00PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 19, 2016 09:45AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 19, 2016 10:40AM |
David J
I really must read release notes - I was just about to report that the Spools page was missing... now I've got to work out some macros!
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 19, 2016 11:51AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 19, 2016 04:36PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 21, 2016 01:15AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 21, 2016 10:41AM |
Treito
There are macros on both sides from chrishamm and dc42 for loading/ unloading filament. Just look at the files for the SD-cards.
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 22, 2016 07:00AM |
mhackney
@chrishamm - a gent on the google delta group asked for screenshots of the DuetWebControl interface. I posted a set there and also on my blog: SublimeLayers. I'd like to make the screenshots available to you to post on the GitHub. In fact, I'd love to pay it forward and write up a description of DuetWebControl and some basic instructions with the screenshots (including installation directly) if you'd like.
regards,
Michael
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 22, 2016 12:03PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 27, 2016 08:49AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch January 30, 2016 10:20AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 14, 2016 05:53AM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 19, 2016 12:40PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 19, 2016 04:33PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 20, 2016 06:42AM |
chrishamm
@JujuDelta: There is no possibility to use a second fan slider yet, but if there is reasonable demand for it, I may add support for that to a future version. Do you actually use two independent cooling fans?
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 20, 2016 01:48PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 20, 2016 03:48PM |
Re: New Duet Web Control 1.08 and RepRapFirmware 1.09r-ch February 21, 2016 10:58AM |
