Install Ramps into Ultimaker2 - possible? February 23, 2016 12:49PM |
Re: Install Ramps into Ultimaker2 - possible? February 25, 2016 02:13PM |
Re: Install Ramps into Ultimaker2 - possible? February 29, 2016 04:25PM |
dintid
Edit: why on Earth use ramps instead of Ulticontroller but keep the little display? No gain here. At all. And an expensivr move to boot.
Re: Install Ramps into Ultimaker2 - possible? February 29, 2016 10:18PM |
Admin Registered: 13 years ago Posts: 7,001 |
Re: Install Ramps into Ultimaker2 - possible? March 01, 2016 01:32AM |
I use silent-stepsticks, and yes, they are awesome... on many controller you can use your own custom step-Sticks though, so you can use a different controller than ramps.Quote
MaxWin
dintid
Gains: Possible use of automatic Fan controll, and - for me the most important - use of SilentStepStick Stepper Drivers - they are incredible!
Re: Install Ramps into Ultimaker2 - possible? March 02, 2016 11:26AM |
Re: Install Ramps into Ultimaker2 - possible? March 02, 2016 03:53PM |
If you allready have bought the display, then go for it. I just seem to remember having read somewhere, that it uses different voltage than normal ramps (which runs stuff on 5v). Maybe look it up on youmagine.com - must be some schematics somehwere, as it is open source.Quote
MaxWin
thanks for that information with the display - seems like a nice replacement if i can not get the original to work.
I mean it must work - but with a lot of effort. and since i mostly use octorpint it is not that important.
I have some sort of Vibration-Feet under my printer, so height is not the problem at all. Maybe i will just go for it, and see how it will come out
