Hello All
Heating up the J - Type Hot End to 185 and I noticed this curve on the graph (See Attachment). Is normal for it to do this, the overheat and then drop temp and over heat. Is there a better way to keep constant Temp? I have already changed TEMP_HYSTERESIS in Configuration.h to 2. Should I leave it at the default 3 or am I crazy for wanting a tighter temp range? Thanks for the Help.
