RAMPS 1.4 Marlin RC8 CONTROLLERFAN_PIN issue
December 28, 2016 11:19AM
Hello,
I am using Marlin 1.10 RC8 with RAMPS 1.4. Printer is custom-built Delta. Board configuration BOARD_RAMPS_14_EFB, with HEATER_BED_PIN assigned to pin 57.
I plan to use D8 output for aux fans control - RAMPS and hot end coolers.
In Configuration_adv.h I changed CONTROLLERFAN_PIN to 8, compilation goes fine, but then nothing happens. I assume 12V should appear at D8 pins when steppers begin to work, but it remains zero.
Have I missed anything or CONTROLLERFAN_PIN can't be assigned to D8?
WBR,
Mikhail
Re: RAMPS 1.4 Marlin RC8 CONTROLLERFAN_PIN issue
December 28, 2016 12:22PM
The mosfet controls the ground side of the connection, the + side is always connected.
December 28, 2016 02:37PM
Thanks, just checked and see 12V between D8 + and ground. Yet the problem persists - always zero between D8+ and D8 -.
December 29, 2016 03:08PM
D8 isn't the cpu pin number, it's the name of the pin.
I believe you need to set CONTROLLERFAN_PIN to 57 and HEATER_BED_PIN to -1, to disable or whatever pin you're using for a heated bed.
December 29, 2016 04:00PM
stephenrc
As I can see on the RAMPS schematic, it is. [reprap.org]
If not, then which CPU pin D8 corresponds to?
stephenrc
In my current configuration pin 57 controls heated bed relay. I can't use D8 output for heated bed because current is too high for RAMPS circuit. That's why I decided to use it for something useful that draws less current.
With proposed changes I won't be able to use heatbed at all.
December 30, 2016 06:51AM
Hello,
thanks for the help, problem is solved. The issue was in missing voltage at secondary power supply.
