Z height zeroing 3mm above switch and build plate while homing
Posted by haleiwa
January 13, 2017 12:10AM
I recently updated my firmware to get my printer going. I am using a Prusa with MKS Base 1.2. when homing Z height moves to the limit switch twice then moves about 3mm above at the end of homing. Z offset is set to zero in slicer and configuration H.
Anyone have any ideas what this could be?
Thank you.
Re: Z height zeroing 3mm above switch and build plate while homing
January 14, 2017 05:08AM
what does #define Z_MIN_POS say in your config?
January 15, 2017 12:24AM
Dust
Config.h
#define Z_MIN_POS 0
I've tried setting the minimum position at -2.5. It appears not to have to do with the final homed position. When MIN_POS is less than 0 it seems to move past the point when the limit switch is triggered and still completes homing in the same position.
I've considered creating a custom gcode start for this machine. not sure if it will work though. The gcode reads correctly and when I look at the commands in Repetier-Host it appears to be executing correctly.
When the machine is moving up after triggering the limit switch it appears to me making two different moves in Z. Like a short deceleration/acceleration.
Any help would be greatly appreciated.
January 20, 2017 04:09PM
What firmware are you using ?
