I recently finished my Darwin build and loaded all the firmware and host software up. I am using Arduino-0022 and when I went to compile the sketch, I got this error:
GCode_Interpreter.cpp:156:29: error: ThermistorTable.h: No such file or directory
GCode_Interpreter.cpp: In function 'void setup()':
GCode_Interpreter:37: error: 'Serial' was not declared in this scope
GCode_Interpreter.cpp: In member function 'void extruder::temperature_error()':
extruder:121: error: 'Serial' was not declared in this scope
GCode_Interpreter.cpp: In function 'void get_and_do_command()':
process_string:82: error: 'Serial' was not declared in this scope
process_string:124: error: 'Serial' was not declared in this scope
GCode_Interpreter.cpp: In function 'void process_string(char*, int)':
process_string:479: error: 'Serial' was not declared in this scope
process_string:542: error: 'Serial' was not declared in this scope
Can someone please help me out with this? I am so close to realizing this project that I can taste it. Please help!!!
