Teacup on Arduino Nano problem in upload (Solved) May 06, 2017 05:24PM |
avrdude -c arduino -b 115200 -p atmega328p -P /dev/ttyUSB0 -U flash:w:"/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex":i avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00 avrdude: stk500_recv(): programmer is not responding avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00 avrdude done. Thank you. RC = 1 - Build terminated Upload terminated abnormally.
avrdude -c arduino -b 115200 -p atmega328p -P /dev/ttyUSB1 -U flash:w:"/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex":i
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "/home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex"
avrdude: writing flash (17308 bytes):
Writing | ################################################## | 100% 2.74s
avrdude: 17308 bytes of flash written
avrdude: verifying flash memory against /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex:
avrdude: load data flash data from input file /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex:
avrdude: input file /home/caslor/Downloads/TEACUPFirmWares/Teacup_Firmware-master/teacup.hex contains 17308 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 2.14s
avrdude: verifying ...
avrdude: 17308 bytes of flash verified
Upload completed normally.
Re: Teacup on Arduino Nano problem in upload May 07, 2017 09:01AM |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Teacup on Arduino Nano problem in upload May 07, 2017 06:39PM |
Re: Teacup on Arduino Nano problem in upload May 08, 2017 01:10AM |
