Teacup firmware and cnc-shield-v3 pins
Posted by caslor
May 22, 2017 12:04PM
Hi
as i am using Arduino Uno and a cnc shield V3 for my project i try to configure the pins to connect the heater for my hotend
In the control panel shows the Heater declares the pin AI02 that is an Analog pin in Arduino uno and doesnt have PWM
The problem is that doesn't allow you to change that and choose one PWM pin to connect the Mofset that will control the Heat element
what have to do to change that?
thanks in advance
Re: Teacup firmware and cnc-shield-v3 pins
May 24, 2017 11:38AM
ok problem solved...
i changed the pin in configuration file... but also i saw that it wasnt necessary to be a PWM pin in order the heater work..
Analog pin can be used also as it is default in the Teacup firmware
