Atmega 2560 and Ramps 1.4
Posted by MarinusK
February 25, 2018 10:00AM
Hi all,
I'm currently busy building a cnc router and I've been searching a while now for some firmware that supports CNC spindle on and off as well as a full graphic smart controller 128 x 64.
Kind regards
Marinus
Re: Atmega 2560 and Ramps 1.4
February 25, 2018 10:22AM
I believe repetier firmware should suffice
You need to enable CNC mode in the tools tab
[www.repetier.com]
February 25, 2018 10:29AM
I tried using Repetier, but Arduino IDE fails to compile the sketch. I keep getting errors like, "operator '>' has no left operand" and I know now to fix that there should be values on both sides, but they are for the temp control that I won't be using..
February 25, 2018 10:31AM
I've attached the Repetier.ino file.
open | download - Repetier.ino (11.5 KB)
