switch X to Z axis controller July 08, 2018 10:17AM |
Re: switch X to Z axis controller July 08, 2018 12:34PM |
Re: switch X to Z axis controller July 08, 2018 12:37PM |
Re: switch X to Z axis controller July 08, 2018 05:44PM |
/**************************************************************************************** * Minitronics v1.0 * ****************************************************************************************/ #if MB(MEGATRONICS_1) #define KNOWN_BOARD 1 #ifndef __AVR_ATmega1281__ #error Oops! Make sure you have 'Minitronics ' selected from the 'Tools -> Boards' menu. #endif #define LARGE_FLASH true #define X_STEP_PIN 48 #define X_DIR_PIN 47 #define X_ENABLE_PIN 49 #define X_MIN_PIN 5 #define X_MAX_PIN -1 //2 //Max endstops default to disabled "-1", set to commented value to enable. #define Y_STEP_PIN 39 // #define Y_DIR_PIN 40 // #define Y_ENABLE_PIN 38 // #define Y_MIN_PIN 2 // #define Y_MAX_PIN -1 // #define Z_STEP_PIN 42 // #define Z_DIR_PIN 43 // #define Z_ENABLE_PIN 41 // #define Z_MIN_PIN 6 // #define Z_MAX_PIN -1 #define E0_STEP_PIN 45 #define E0_DIR_PIN 44 #define E0_ENABLE_PIN 27 #define E1_STEP_PIN 36 #define E1_DIR_PIN 35 #define E1_ENABLE_PIN 37 #define E2_STEP_PIN -1 #define E2_DIR_PIN -1 #define E2_ENABLE_PIN -1 #define SDPOWER -1 #define SDSS 16 #define LED_PIN 46 #define FAN_PIN 9 #define FAN2_PIN -1 #define PS_ON_PIN -1 #define KILL_PIN -1 #define HEATER_0_PIN 7 // EXTRUDER 1 #define HEATER_1_PIN 8 // EXTRUDER 2 #define HEATER_2_PIN -1 #define TEMP_0_PIN 7 // ANALOG NUMBERING #define TEMP_1_PIN 6 // ANALOG NUMBERING #define TEMP_2_PIN -1 // ANALOG NUMBERING #define HEATER_BED_PIN 3 // BED #define TEMP_BED_PIN 6 // ANALOG NUMBERING #define BEEPER -1 #define LCD_PINS_RS -1 #define LCD_PINS_ENABLE -1 #define LCD_PINS_D4 -1 #define LCD_PINS_D5 -1 #define LCD_PINS_D6 -1 #define LCD_PINS_D7 -1 //buttons are directly attached using keypad #define BTN_EN1 -1 #define BTN_EN2 -1 #define BTN_ENC -1 //the click #define BLEN_C 2 #define BLEN_B 1 #define BLEN_A 0 #define SDCARDDETECT -1 // Megatronics does not use this port //encoder rotation values #define encrot0 0 #define encrot1 2 #define encrot2 3 #define encrot3 1 #endif // MEGATRONICS_1
