Rep Rap LCD Display goes blank
Posted by ekozikow
November 12, 2018 04:47PM
Hey Guys, new to the forum. I built a printer a few years back and I'm having an issue with the LCD display. Its a basic rep rap display kit. It's worked fine for all this time and now all of the sudden, after I start the print, the lettering disappear and its just blank. Everything works fine, even up to when I start the print, but after a min or two of printing, it goes blank.
Some background
Display:
[www.ebay.com]
The printer is a flex-mendel style printer
Re: Rep Rap LCD Display goes blank
November 13, 2018 04:04AM
If you are using Arduino/RAMPS hardware, then the 5V regulator on the Arduino is probably overheating.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
November 13, 2018 06:26AM
I would also measure the Voltage at The Power Supply again at the controller. If you have a voltage drop on the controller then wiring is in-sufficient for the 3D Printer.
If voltage is the same then try display contrast control on the back of the RepRap display PCB.
Electronics Technician / Computer Programmer
