MK4 Duo for Scara
Posted by Mauxx
MK4 Duo for Scara
January 12, 2019 07:01AM
Hello,
Can MK4 Duo working for scara morgan/makerarm?
I tried to configure and give this error:
In file included from sketch\src/inc/sanitycheck.h:101:0,
from sketch\MK4duo.h:108,
from C:\Users\XXXXX\AppData\Local\Temp\arduino_modified_sketch_28165\MK4duo.ino:323:
sanitycheck.h:258: error: #error "DEPENDENCY ERROR: Missing setting DEFAULT_MIN_TRAVEL_FEEDRATE."
exit status 1
someone could help me?
Thanks in advance
Re: MK4 Duo for Scara
January 25, 2019 10:31AM
Hi! winking smiley
Did you get a solution already?
Using RAMPS 1.4 - ATmega2560
I just tried the compilation of the firmware by enabling configuration to scara and I get exactly the same error.
If I get a solution I'll post it here!
Edited 3 time(s). Last edit at 01/25/2019 11:03AM by ricardocjcosta.
January 26, 2019 01:30PM
Hi Mauxx!
Go to class CONFIGURATION_SCARA_H and write
// Minimum feedrate
#define DEFAULT_MIN_FEEDRATE 0.0
#define DEFAULT_MIN_TRAVEL_FEEDRATE 0.0
instead of
#define DEFAULT_MINIMUMFEEDRATE 0.0 // minimum feedrate
#define DEFAULT_MINTRAVELFEEDRATE 0.0
However, after correcting this problem, I found others that I was not able to solve.
I left a message (https://github.com/MKFirmware/MK4duo/issues/259), explaining what was happening and MagoKimbra told that the problem was fixed. I've checked [github.com] ando I saw they have updated the files. It compiles now! winking smiley
