Hi all,
in the
config.g file, on my machine, I've found the string:
M307 H4 A-1 C-1 D-1
This is good because
I need to disable bed heating during probing moments, anyway
the command does not seem to work (my machine indicate me when the bed and tool are heated on it's embedded screen.)
So, I would ask you:
- How to check the bed heating while probing?
- How, precisely, M307 command works?
- I've checked that "H0" is the heater for my bed. Why shouldn't I use "M307 H0" instead of "M307 H4"?
Please note that my "
config-override.g" file contains M307 instructions for M307 H0 and for H7, but not for H4.
Thank you so much!
P.S. some info about my machine:
- Firmware name: RepRapFirmware for Duet 2 WiFi Ethernet
- Firmware electronics: Duet Ethernet 1.02 or later + DueX2
- Firnware version: 1.21 (2018-03-21)
Understanding the universe since the last century.
