Z axis Buggy configuration June 04, 2011 05:34PM |
Re: Z axis Buggy configuration June 04, 2011 06:27PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Z axis Buggy configuration June 04, 2011 07:13PM |
Re: Z axis Buggy configuration June 04, 2011 07:35PM |
Once you enable the limit feature in skeinforge it will look like this.Quote
No Z speed limit between layers
G1 X-2.7 Y-0.15 Z0.2 F2400.0 E4.0299
G1 X-2.57 Y0.82 Z0.2 F2400.0 E0.9828
G1 X-1.67 Y1.72 Z0.2 F2400.0 E1.2731
M103
G1 X-0.97 Y2.43 Z0.58 F4800.0 <--- Z move at travel rate in skeinforge
M101
G1 X-1.07 Y2.38 Z0.6 F2400.0 E0.115 <--- Z move at feed rate in skeinforge
G1 X-1.46 Y2.18 Z0.6 F2400.0 E0.433
G1 X-1.86 Y1.86 Z0.6 F2400.0 E0.5165
With Z speed limit between layers
M103
G1 X-0.97 Y2.43 Z0.58 F40.9745 <--- Z move at max set speed in skeinforge
M101
G1 X-1.07 Y2.38 Z0.6 F174.7307 E1.58 <--- Z move at max set speed in skeinforge
Re: Z axis Buggy configuration June 04, 2011 07:38PM |
Re: Z axis Buggy configuration June 05, 2011 12:17PM |
Re: Z axis Buggy configuration June 05, 2011 12:22PM |
Re: Z axis Buggy configuration June 05, 2011 01:30PM |
Re: Z axis Buggy configuration June 05, 2011 01:50PM |
Re: Z axis Buggy configuration June 05, 2011 03:03PM |
Re: Z axis Buggy configuration June 05, 2011 04:14PM |
Re: Z axis Buggy configuration June 06, 2011 12:48PM |
Re: Z axis Buggy configuration June 06, 2011 05:36PM |
Re: Z axis Buggy configuration June 08, 2011 07:06PM |
