Hi All,
I have a larger bed which is 300mmx300mm and the z axis does 150mm. Do i adjust this in the firmware in configuration H?
//Endstop Settings
//if you do not have max hardware endstops, it defaults to software endstops, defined by the max length numbers.
//if you do not have min hardware endstops, the firmware will not move to lengths less than 0
//#define USE_INTERNAL_PULLUPS
const bool ENDSTOPS_INVERTING = true;
//const bool x_max_hardware = false;
const bool x_min_hardware = true;
const int X_MAX_LENGTH = 300;
//const bool y_max_hardware = false;
const bool y_min_hardware = true;
const int Y_MAX_LENGTH = 300;
//const bool z_max_hardware = false;
const bool z_min_hardware = true;
const int Z_MAX_LENGTH = 150;
Would this be correct? or have i completely mis understood?
Cheers
