From the beginning I have to say I'm a newbie in programming.
What I want is adjust/fine tune the travel feed of my existing printer.
There are 2 reasons.
1. The speed is really low (comparable to homing speed) and I want to make it a bit higher.
2. I have made a jog controller
https://www.thingiverse.com/thing:3404797 connected to board's rx/tx . In 10mm/pulse setting I want to match the physical speed with command pulse speed so that I don't have overtravel (and if possible no stepped movement in the opposite case) when I release the joystick.
The target speed should be somewhere around 1.5x what I have now and I'm prepared to tinker it.
I haven't found yet anywhere a relevant thread about this.
Thanks in advance.
ND
