RepRapFirmware 2.04 and 3.0beta12 released
Posted by dc42
November 02, 2019 10:13AM
I released RepRapFirmware 2.04 yesterday at [github.com]. This is intended to be the last release in the RepRapFirmware 2 series, because development has now moved to RepRapFirmware 3. Pre-built binaries are provided for Duet 06/085, Duet WiFi/Ethernet, Duet Maestro, and Arduino Due/RADDS.
Today I released RepRapFirmware 3.0beta12 at [github.com]. Pre-built binaries are provided for Duet 3, Duet WiFi/Ethernet, and Duet Maestro. RRF3 provides highly flexible pin allocation which, like everything else, can be configured at boot time or even at run time. It also supports CAN-connected expansion boards on Duet 3.
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
Re: RepRapFirmware 2.04 and 3.0beta12 released
November 06, 2019 12:11AM
Thanks for your RADDS support smiling smiley
November 23, 2019 08:29AM
Working on a small RepRap fw compatible board shown at: https://reprap.org/forum/read.php?159,862626
Would you be able to fix RRF, SAM4S variant to compile when:
#define HAS_WIFI_NETWORKING 1
#define SUPPORT_TMC22xx 0
November 23, 2019 05:39PM
Which file fails to compile? Have you defined the pins and SPI channel used to interface to the WiFi module?
Edited 1 time(s). Last edit at 11/23/2019 05:41PM by dc42.
November 24, 2019 05:34AM
dc42
Yes, the pins are defined. Attached Pins_DuetM.h.
Errors:
Building file: ../src/Networking/FtpResponder.cpp
Invoking: Cross G++ Compiler
arm-none-eabi-g++ -std=gnu++17 -D__SAM4S8C__ -DRTOS -DDUET_M -D_XOPEN_SOURCE -I"C:\Eclipse\RRFLibraries" -I"C:\Eclipse\FreeRTOS" -I"C:\Eclipse\CoreNG" -I"C:\Eclipse\CoreNG\cores\arduino" -I"C:\Eclipse\CoreNG\libraries\Flash" -I"C:\Eclipse\CoreNG\libraries\SharedSpi" -I"C:\Eclipse\CoreNG\libraries\Storage" -I"C:\Eclipse\CoreNG\libraries\Wire" -I"C:\Eclipse\CoreNG\asf" -I"C:\Eclipse\CoreNG\asf\common\utils" -I"C:\Eclipse\CoreNG\asf\common\services\clock" -I"C:\Eclipse\CoreNG\asf\common\services\ioport" -I"C:\Eclipse\CoreNG\asf\sam\drivers" -I"C:\Eclipse\CoreNG\asf\sam\services\flash_efc" -I"C:\Eclipse\CoreNG\asf\sam\utils" -I"C:\Eclipse\CoreNG\asf\sam\utils\cmsis\sam4s\include" -I"C:\Eclipse\CoreNG\asf\sam\utils\header_files" -I"C:\Eclipse\CoreNG\asf\sam\utils\preprocessor" -I"C:\Eclipse\CoreNG\asf\thirdparty\CMSIS\Include" -I"C:\Eclipse\CoreNG\variants\sam4s" -I"C:\Eclipse\RepRapFirmware\src" -I"C:\Eclipse\RepRapFirmware\src\DuetM" -I"C:\Eclipse\RepRapFirmware\src\Networking" -I"C:\Eclipse\DuetWiFiSocketServer\src\include" -I"C:\Eclipse\FreeRTOS\src\include" -I"C:\Eclipse\FreeRTOS\src\portable\GCC\ARM_CM3" -I"C:\Eclipse\RRFLibraries\src" -O2 -Wall -c -mcpu=cortex-m4 -mthumb -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wdouble-promotion -fsingle-precision-constant "-Wa,-ahl=FtpResponder.s" -MMD -MP -MF"src/Networking/FtpResponder.d" -MT"src/Networking/FtpResponder.o" -o "src/Networking/FtpResponder.o" "../src/Networking/FtpResponder.cpp"
../src/Networking/FirmwareUpdater.cpp: In function 'bool FirmwareUpdater::CheckFirmwareUpdatePrerequisites(uint8_t, const StringRef&)':
../src/Networking/FirmwareUpdater.cpp:35:105: error: 'WIFI_FIRMWARE_FILE' was not declared in this scope
if ((moduleMap & (1 << WifiFirmwareModule)) != 0 && !reprap.GetPlatform().FileExists(DEFAULT_SYS_DIR, WIFI_FIRMWARE_FILE))
../src/Networking/FirmwareUpdater.cpp:35:105: note: suggested alternative: 'IAP_FIRMWARE_FILE'
IAP_FIRMWARE_FILE
../src/Networking/FirmwareUpdater.cpp: In function 'void FirmwareUpdater::UpdateModule(unsigned int)':
../src/Networking/FirmwareUpdater.cpp:72:32: error: 'WIFI_FIRMWARE_FILE' was not declared in this scope
uploader->SendUpdateFile(WIFI_FIRMWARE_FILE, DEFAULT_SYS_DIR, WifiFirmwareUploader::FirmwareAddress);
../src/Networking/FirmwareUpdater.cpp:72:32: note: suggested alternative: 'IAP_FIRMWARE_FILE'
IAP_FIRMWARE_FILE
src/Networking/subdir.mk:39: recipe for target 'src/Networking/FirmwareUpdater.o' failed
make: *** [src/Networking/FirmwareUpdater.o] Error 1
make: *** Waiting for unfinished jobs....
Finished building: ../src/Networking/FtpResponder.cpp
Pins_DuetM.h
November 25, 2019 02:08AM
You haven't defined WIFI_FIRMWARE_FILE in your Pins file.
November 25, 2019 03:23AM
dc42
Thanks, still issues:
Building target: DuetMaestroFirmware.elf
Invoking: Cross G++ Linker
arm-none-eabi-gcc -L"C:\Eclipse\CoreNG\SAM4S" -L"C:\Eclipse\CoreNG\SAM4S" -L"C:\Eclipse\FreeRTOS\SAM4S" -L"C:\Eclipse\RRFLibraries\SAM4S_RTOS" -Os --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -mcpu=cortex-m4 -T"C:\Eclipse\CoreNG\variants\sam4s\linker_scripts\gcc\flash.ld" -Wl,-Map,"C:\Eclipse\RepRapFirmware\DuetM_RTOS/DuetMaestroFirmware.map" -o "DuetMaestroFirmware.elf" -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--entry=Reset_Handler -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Eclipse/CoreNG/SAM4S/cores/arduino/syscalls.o" ./src/Tools/Filament.o ./src/Tools/Tool.o ./src/Storage/CRC32.o ./src/Storage/FileInfoParser.o ./src/Storage/FileStore.o ./src/Storage/MassStorage.o ./src/ObjectModel/ObjectModel.o ./src/Networking/W5500Ethernet/Wiznet/Internet/DHCP/dhcp.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/W5500/w5500.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/WizSpi.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/socketlib.o ./src/Networking/W5500Ethernet/Wiznet/Ethernet/wizchip_conf.o ./src/Networking/W5500Ethernet/MdnsResponder.o ./src/Networking/W5500Ethernet/W5500Interface.o ./src/Networking/W5500Ethernet/W5500Socket.o ./src/Networking/FirmwareUpdater.o ./src/Networking/FtpResponder.o ./src/Networking/HttpResponder.o ./src/Networking/Network.o ./src/Networking/NetworkBuffer.o ./src/Networking/NetworkResponder.o ./src/Networking/TelnetResponder.o ./src/Networking/UploadingNetworkResponder.o ./src/Movement/StepperDrivers/DriverMode.o ./src/Movement/StepperDrivers/TMC22xx.o ./src/Movement/StepperDrivers/TMC2660.o ./src/Movement/StepperDrivers/TMC51xx.o ./src/Movement/Kinematics/CoreKinematics.o ./src/Movement/Kinematics/HangprinterKinematics.o ./src/Movement/Kinematics/Kinematics.o ./src/Movement/Kinematics/LinearDeltaKinematics.o ./src/Movement/Kinematics/PolarKinematics.o ./src/Movement/Kinematics/RotaryDeltaKinematics.o ./src/Movement/Kinematics/ScaraKinematics.o ./src/Movement/Kinematics/ZLeadscrewKinematics.o ./src/Movement/BedProbing/Grid.o ./src/Movement/BedProbing/RandomProbePointSet.o ./src/Movement/DDA.o ./src/Movement/DDARing.o ./src/Movement/DriveMovement.o ./src/Movement/Move.o ./src/Movement/StepTimer.o ./src/Libraries/sha1/sha1.o ./src/Libraries/Fatfs/diskio.o ./src/Libraries/Fatfs/fattime_rtc.o ./src/Libraries/Fatfs/ff.o ./src/Libraries/Fatfs/ffunicode.o ./src/Heating/Sensors/CpuTemperatureSensor.o ./src/Heating/Sensors/CurrentLoopTemperatureSensor.o ./src/Heating/Sensors/DhtSensor.o ./src/Heating/Sensors/RtdSensor31865.o ./src/Heating/Sensors/SpiTemperatureSensor.o ./src/Heating/Sensors/TemperatureSensor.o ./src/Heating/Sensors/Thermistor.o ./src/Heating/Sensors/ThermocoupleSensor31855.o ./src/Heating/Sensors/ThermocoupleSensor31856.o ./src/Heating/Sensors/TmcDriverTemperatureSensor.o ./src/Heating/FOPDT.o ./src/Heating/Heat.o ./src/Heating/HeaterProtection.o ./src/Heating/Pid.o ./src/Heating/TemperatureError.o ./src/Hardware/DmacManager.o ./src/Hardware/I2C.o ./src/Hardware/IoPorts.o ./src/GCodes/GCodeBuffer.o ./src/GCodes/GCodeInput.o ./src/GCodes/GCodeMachineState.o ./src/GCodes/GCodeQueue.o ./src/GCodes/GCodes.o ./src/GCodes/GCodes2.o ./src/GCodes/GCodes3.o ./src/GCodes/RestorePoint.o ./src/FilamentMonitors/Duet3DFilamentMonitor.o ./src/FilamentMonitors/FilamentMonitor.o ./src/FilamentMonitors/LaserFilamentMonitor.o ./src/FilamentMonitors/PulsedFilamentMonitor.o ./src/FilamentMonitors/RotatingMagnetFilamentMonitor.o ./src/FilamentMonitors/SimpleFilamentMonitor.o ./src/Fans/DotStarLed.o ./src/Fans/Fan.o ./src/Fans/Tacho.o ./src/Display/ST7920/glcd11x14.o ./src/Display/ST7920/glcd7x11.o ./src/Display/ST7920/lcd7920.o ./src/Display/Display.o ./src/Display/Menu.o ./src/Display/MenuItem.o ./src/Display/RotaryEncoder.o ./src/CAN/CanInterface.o ./src/CAN/CanMessageBuffer.o ./src/CAN/CanSender.o ./src/Logger.o ./src/OutputMemory.o ./src/Platform.o ./src/PortControl.o ./src/PrintMonitor.o ./src/RepRap.o ./src/RepRapFirmware.o ./src/Roland.o ./src/Scanner.o ./src/SoftTimer.o ./src/Spindle.o ./src/Tasks.o ./src/ZProbe.o ./src/ZProbeProgrammer.o -lCoreNG -lCoreNG -lFreeRTOS -lRRFLibraries -Wl,--end-group -lm
c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ./src/Networking/FirmwareUpdater.o: in function `FirmwareUpdater::IsReady()':
FirmwareUpdater.cppsad smiley.text._ZN15FirmwareUpdater7IsReadyEv+0x10): warning: undefined reference to `WifiFirmwareUploader::IsReady() const'
c:/program files (x86)/gnu tools arm embedded/8 2018-q4-major/bin/../lib/gcc/arm-none-eabi/8.2.1/../../../../arm-none-eabi/bin/ld.exe: ./src/Networking/Network.o: in function `Network::HandleWiFiCode(int, GCodeBuffer&, StringRef const&, OutputBuffer*&)':
Network.cppsad smiley.text._ZN7Network14HandleWiFiCodeEiR11GCodeBufferRK9StringRefRP12OutputBuffer+0x38): warning: undefined reference to `WiFiInterface::HandleWiFiCode(int, GCodeBuffer&, StringRef const&, OutputBuffer*&)'
collect2.exe: error: ld returned 1 exit status
makefile:73: recipe for target 'DuetMaestroFirmware.elf' failed
make: *** [DuetMaestroFirmware.elf] Error 1
November 25, 2019 02:39PM
Looks like your build configuration excludes the Networking/ESP8266WiFi folder, because I don't see any of those files in the linker input list. OTOH it does include the W5500 Ethernet files, which it shouldn't do if your board has WiFi instead.
Edited 1 time(s). Last edit at 11/25/2019 02:40PM by dc42.
