Repieter Arduino program shows def on thermistors
Posted by zurferjoe
January 31, 2020 07:18AM
On my printer , I keep getting the def on my thermistors for the bed and the extruder .I have put 2 new thermistors on both devices but it still shows DEF ,Any ideas what this could be ? Hope so !
Re: Repieter Arduino program shows def on thermistors
January 31, 2020 07:33PM
This happens if no thermistors are connected or the thermistors have a short or are broken or are plugged on the wrong pins or configured wrong. Or the motherboard has a fault.
Unfortunately this firmware sets defective on both thermistors and doesn't tell you which one is causing the issue.
Unplug the thermistors from the board. Measure the thermistor resistance including the full cable length from the thermitor cable plug. Should be about 100k at room temperature.
If they read OK, the firmware is reading the wrong pins, or a damaged pins on the controller.
Edited 1 time(s). Last edit at 02/01/2020 12:03AM by Dust.
