trigorilla 2560 fan2 port does not work, fan0 and fan1 ports do work, but fans are always at 100% and the printer's display wrongly report them at 0% January 21, 2022 09:43PM |
Re: trigorilla 2560 fan2 port does not work, fan0 and fan1 ports do work, but fans are always at 100% and the printer's display wrongly report them at 0% January 22, 2022 08:06AM |
//#define E1_DRIVER_TYPE A4988 //#define E2_DRIVER_TYPE A4988
// For Cyclops or any "multi-extruder" that shares a single nozzle. //#define SINGLENOZZLEshould enable this "Has_Multi_Hotend" for pins_TRIGORILLA_14
#define TG_FAN0_PIN 9 // Anycubic Kossel: Usually the part cooling fan #define TG_FAN1_PIN 7 // Anycubic Kossel: Unused #define TG_FAN2_PIN 44 // Anycubic Kossel: Hotend fan #if HAS_MULTI_HOTEND || TEMP_SENSOR_BED // EEF, EEB, EFB #define FAN1_PIN TG_FAN1_PIN #endif #define FAN2_PIN TG_FAN2_PIN
Re: trigorilla 2560 fan2 port does not work, fan0 and fan1 ports do work, but fans are always at 100% and the printer's display wrongly report them at 0% January 24, 2022 10:21AM |
Roberts_Clif
I believe you need to enable these before the fans can function correctly.
If you are using a single extruder in pins_TRIGORILLA_14 and connect fan2 to pin 44
should enable this to allow "Has_Multi_Hotend" for pins_TRIGORILLA_14
// This defines the number of extruders // :[0, 1, 2, 3, 4, 5, 6, 7, 8] #define EXTRUDERS 1 //this definition, to 2, 3 or whatever // Generally expected filament diameter (1.75, 2.85, 3.0, ...). Used for Volumetric, Filament Width Sensor, etc. #define DEFAULT_NOMINAL_FILAMENT_DIA 1.75 // For Cyclops or any "multi-extruder" that shares a single nozzle. #define SINGLENOZZLE // Save and restore temperature and fan speed on tool-change. // Set standby for the unselected tool with M104/106/109 T... #if ENABLED(SINGLENOZZLE) //#define SINGLENOZZLE_STANDBY_TEMP //#define SINGLENOZZLE_STANDBY_FAN #endif
