So a few teething issues as follows any help would be much appreciated please.
I apologise if my terminology is poor this side of machine building is definately not my forte but willing to learn !
Im wanting to home both X and Y axis at MINIMA or front left as i keep calling it
Is my config in the correct order ?
Im using a Millenium Milo file as my basis to get started
[github.com]
So have done a fresh flash and onto my wifi network all good
Z axis direction is good and homes at top of travel and the Maxima travel downwards direction is spot on and stops at 350
The X axis on X homing travels in the wrong direction X+ in movements of 5mm everytime the home X button is pressed ?
The Y axis on Y homing travels in the wrong direction Y+ and the additional stepper (A) on the Y axis moves further than the Y stepper by double the amount at a rough guess maybe microstepping need a definition for the A drive ?
Once the second ( slow home ) home on the Z drive is done it needs to move further away from the limit stop as its still resting on it if this is an issue ? This maybe the case for all 3 axis (edited)
; user-config.g - Configure machine or user-specific overrides
; Set steps per mm.
M92 X640 Y640 Z640
;M569 P3 S1
; Set drive mappings to relevant axes
M584 X0 Y1:3 Z2
; Configure acceleration
M201 X300 Y300 Z200
; Configure maximum speeds
M203 X2500 Y2500 Z2000
; Endstop X=MIN: NC
M574 X1 S1 P"PC_6"
; Endstop Y=MIN: NC
M574 Y1 S1 P"PA_8"
; Endstop Z=MAX: NC
M574 Z2 S1 P"PD_12"
; Set axis limits - minima
M208 X0 Y0 Z-350 S1
; Set axis limits - maxima
M208 X1450 Y2200 Z0 S0
; Configure jerk
M566 X500 Y500 Z200
Edited 2 time(s). Last edit at 02/26/2025 06:53AM by Scylla CNC Build.
