Duet2wifi RepRap CNC
Posted by MARCENEIRO JOVEM
November 21, 2025 06:00PM
Hello everyone.
I’m asking for help because I have already exhausted research and assistance from Artificial Intelligence Gemini and CoPilot. The problem: I have an operational CNC machine and decided to upgrade to a Duet2 Wifi controller. Everything worked except the Z-axis movement. It always moves 1/5 of the requested distance. For example, if I request a movement (positive or negative) via Web Control of 25 mm, it only moves 5 mm. If I change steps per mm M92, it produces almost no change. I have checked the Z-axis hardware and everything seems ok. Homing is OK. I have no idea what to do.
My setup: Duet2 Wifi controller, RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.1., Z axis Threaded Rod Stainless Steel M8x2mm Nema 23 motors (AK23/15F6FN1.8 model). Power supply 12v/ 30A), mechanical endstop switch.
Attached Config.g e Diagnostics.
Noconfirmado550904.crdownload
DiagnosticsM122.txt
I appreciate any help because I really don't know what to do.
Re: Duet2wifi RepRap CNC
November 22, 2025 07:24AM
I already tested it with another engine and the result was the same.
November 22, 2025 08:35AM
"M201 X100 Y100 Z2000 ; set accelerations (mm/s^2)"
This seems like a lot of acceleration for a Z, perhaps this is causing z to skip steps
November 24, 2025 04:05PM
Thanks for the tip.
I reduced the acceleration to 10 and there was no change.
November 26, 2025 06:28PM
Could it be that I have an unsolvable problem?
November 27, 2025 02:44AM
Please post at [forum.duet3d.com] where the Duet3D support team will be pleased to help you.
Edit: I see that you have done so.
Edited 1 time(s). Last edit at 11/27/2025 03:04AM by dc42.
November 27, 2025 06:58PM
Solved with the help of DC42 and droftart from forum.duet3d.com.
The problem was a corrupted SD card that didn't allow saving value changes. The Z-axis Steps/mm remained at 400 the whole time, when it should have been 1600.
A new SD card solved it.
VDX
November 28, 2025 09:02AM
smileys with beer
Viktor
