Help understanding the Firmware
Posted by shippo0708
September 14, 2011 09:09AM
What i mean by help is a couple questions I'm a little stuck on, I downloaded a version of FiveD that will work on an atmega328 (since this is what i use am familiar with) but I can eventually get a Sanguinololu if need be.
I know that the Firmware is:
Responsible for interpreting G-Code
Controlling the stepper motors
Manipulating the extruder with the correct G-Code
Communicating with the PC
What I'm unsure of is:
Does the firmware control the extruder temperature?
Does it control the bed temperature?
My goal is to build a mill AND reprap in one, so i would like to know if i can either segment the "heated" control into another circuit OR add a switch and just tweak the firmware so when the switch is in one position it doesn't start/control heating.
Re: Help understanding the Firmware
September 15, 2011 06:00AM
Both: yes.
September 15, 2011 12:30PM
so then can i assume if i use the firmware everyone else on here uses, i can mill and print from the same machine? just by swapping out tools?
September 16, 2011 05:22AM
There are at least 4 Firmwares "everybody else" uses: FiveD, Teacup, Sprinter, Marlin. Regarding Teacup I can confirm it works for full 3D milling, even if spindle on/off commands aren't fully evolved, yet.
