Printing from SDCard while uploading g-code from Host November 24, 2011 11:58PM |
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 10:53AM |
M29 M23 filename_form_upload M24
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 01:24PM |
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 01:51PM |
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 02:15PM |
Why do you want this? If you have communication errors or a hardware failure you still have a ruined print. What is the advantage to direct print? The only advantage I see is, you can shut your computer down, when the upload is finished.
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 04:55PM |
Re: Printing from SDCard while uploading g-code from Host November 25, 2011 09:54PM |
If you don't want to remove your sd card, you can still increase communication speed and use data compression. Thats what I do with my Host/Firmware. Speed 250000 Baud and the binary format is 50% shorter compared to ascii format.
Re: Printing from SDCard while uploading g-code from Host November 26, 2011 06:19AM |
