Sprinter Firmware for Generation 7 Electronics February 16, 2012 05:34PM |
extern const uint16_t PROGMEM port_to_mode_PGM[]; extern const uint16_t PROGMEM port_to_input_PGM[]; extern const uint16_t PROGMEM port_to_output_PGM[]; unsigned long pulseIn(uint8_t pin, uint8_t state, unsigned long timeout = 1000000L);
// Gen 7 Board = 7Change the board type:
#define MOTHERBOARD 7Comment the following lines as SD and fan aren't supported in Gen 7:
#define SDSUPPORT
#define CONTROLLERFAN_SEC 60 //How many seconds, after all motors were disabled, the fan should run
/**************************************************************************************** * Gen 7 Motherboard * * ATMega644/ATMega644P * * +---\/---+ * (D 0) PB0 1| |40 PA0 (AI 0 / D31) * (D 1) PB1 2| |39 PA1 (AI 1 / D30) * INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29) * PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28) * PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27) * MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26) * MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25) * SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24) * RST 9| |32 AREF * VCC 10| |31 GND * GND 11| |30 AVCC * XTAL2 12| |29 PC7 (D 23) * XTAL1 13| |28 PC6 (D 22) * RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI * TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO * INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS * INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK * PWM (D 12) PD4 18| |23 PC1 (D 17) SDA * PWM (D 13) PD5 19| |22 PC0 (D 16) SCL * PWM (D 14) PD6 20| |21 PD7 (D 15) PWM * +--------+ * ****************************************************************************************/ #if MOTHERBOARD == 7 #define KNOWN_BOARD 1 #if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega1284P__) && !defined(__AVR_ATmega644__) #error Oops! Make sure you have 'Gen 7' selected from the 'Tools -> Boards' menu. #endif #define X_STEP_PIN 19 #define X_DIR_PIN 18 #define X_MIN_PIN 7 #define X_MAX_PIN 6 #define X_ENABLE_PIN 24 #define Y_STEP_PIN 23 #define Y_DIR_PIN 22 #define Y_MIN_PIN 5 #define Y_MAX_PIN 2 #define Y_ENABLE_PIN 24 #define Z_STEP_PIN 26 #define Z_DIR_PIN 25 #define Z_MIN_PIN 1 #define Z_MAX_PIN 0 #define Z_ENABLE_PIN 24 #define E_STEP_PIN 28 #define E_DIR_PIN 27 #define E_ENABLE_PIN 24 #define PS_ON_PIN 15 #define STEPPER_ENABLE_PIN 24 #define SDPOWER -1 #define SDSS -1 #define LED_PIN -1 #define FAN_PIN -1 #define KILL_PIN -1 #define ALARM_PIN -1 #define HEATER_0_PIN 4 #define TEMP_0_PIN 1//D30 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! #define HEATER_1_PIN 3 #define TEMP_1_PIN 2//D29 // MUST USE ANALOG INPUT NUMBERING NOT DIGITAL OUTPUT NUMBERING!!!!!!!!! /* Unused (0) (1) (2) (3) (4) (5) (6) (7) 8 9 10 11 12 13 14 (15) 16 17 (18) (19) 20 21 (22) (23) (24) (25) (26) (27) (28) (29) (30) 31 */ #endif
Re: Sprinter Firmware for Generation 7 Electronics February 17, 2012 04:47AM |
Admin Registered: 15 years ago Posts: 2,569 |
Re: Sprinter Firmware for Generation 7 Electronics February 17, 2012 06:23AM |
Re: Sprinter Firmware for Generation 7 Electronics February 17, 2012 06:54AM |
Re: Sprinter Firmware for Generation 7 Electronics February 17, 2012 09:24AM |
Re: Sprinter Firmware for Generation 7 Electronics December 24, 2012 02:29PM |
Re: Sprinter Firmware for Generation 7 Electronics December 25, 2012 05:06AM |
