Adding heated build plate Gcodes to firmware September 20, 2010 11:00PM |
M104 S225.0 T0 (barrel temp to 225 DEG C) M109 S110.0 T0 (Build plate to 110 DEG C)While I can edit Tonokip's firmware to work like that, it isn't clear to me why T0 in one instance represents the HBP and T0 in another represents the extruder or if the reprap tool chain is even set up to use the same Gcode in the same manner.
Re: Adding heated build plate Gcodes to firmware September 21, 2010 12:51AM |
Re: Adding heated build plate Gcodes to firmware September 21, 2010 05:20PM |
Re: Adding heated build plate Gcodes to firmware September 22, 2010 03:08AM |
Re: Adding heated build plate Gcodes to firmware September 22, 2010 03:36AM |
# 4 Individual commands * 4.1 Checking o 4.1.1 N and * * 4.2 Buffered G Commands o 4.2.1 G0: Rapid move o 4.2.2 G1: Controlled move o 4.2.3 G28: Move to Origin * 4.3 Unbuffered G commands o 4.3.1 G4: Dwell o 4.3.2 G20: Set Units to Inches o 4.3.3 G21: Set Units to Millimeters o 4.3.4 G90: Set to Absolute Positioning o 4.3.5 G91: Set to Relative Positioning o 4.3.6 G92: Set Position * 4.4 Unbuffered M and T commands o 4.4.1 M0: Stop o 4.4.2 M104: Set Extruder Temperature (Fast) o 4.4.3 M105: Get Extruder Temperature o 4.4.4 M106: Fan On o 4.4.5 M107: Fan Off o 4.4.6 M108: Set Extruder Speed o 4.4.7 M109: Set Extruder Temperature o 4.4.8 M110: Set Current Line Number o 4.4.9 M111: Set Debug Level o 4.4.10 M112: Emergency Stop o 4.4.11 M113: Set Extruder PWM o 4.4.12 M114: Get Current Position o 4.4.13 M115: Get Firmware Version and Capabilities o 4.4.14 M116: Wait o 4.4.15 M117: Get Zero Position o 4.4.16 M126: Open Valve o 4.4.17 M127: Close Valve o 4.4.18 M140: Bed Temperature (Fast) o 4.4.19 M141: Chamber Temperature (Fast) o 4.4.20 M142: Holding Pressure o 4.4.21 T: Select Tool * 4.5 RepRap G-Code Summary Table
Re: Adding heated build plate Gcodes to firmware September 22, 2010 04:39PM |
