firmware stops you directly playing with IO pins that are under control of the controller
ie in pins.h
#define SENSITIVE_PINS { 0, 1, \
X_STEP_PIN, X_DIR_PIN, X_ENABLE_PIN, X_MIN_PIN, X_MAX_PIN, \
Y_STEP_PIN, Y_DIR_PIN, Y_ENABLE_PIN, Y_MIN_PIN, Y_MAX_PIN, \
Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, Z_MIN_PIN, Z_MAX_PIN, Z_MIN_PROBE_PIN, \
PS_ON_PIN, HEATER_BED_PIN,
FAN_PIN, FAN1_PIN, FAN2_PIN, CONTROLLERFAN_PIN, \
_E0_PINS _E1_PINS _E2_PINS _E3_PINS _E4_PINS BED_PINS \
_H0_PINS _H1_PINS _H2_PINS _H3_PINS _H4_PINS \
_X2_PINS _Y2_PINS _Z2_PINS \
X_MS1_PIN, X_MS2_PIN, Y_MS1_PIN, Y_MS2_PIN, Z_MS1_PIN, Z_MS2_PIN \
you can remove it from the above list... but it will confuse the controller, thinking fan is on when your turn it off etc...
Edited 1 time(s). Last edit at 04/12/2017 06:06AM by Dust.
