[Repetier Firmware} and the Printrboard Rev D
Posted by draeician
February 23, 2013 03:53AM
I have downloaded the arduinio 0022, and copied the at90can/at90usb1286/Sanguino folders to the arduinio 1.0.3 Hardware folder. The motherboard is set to '9' in the configuration.h, the bootloader has been flashed with CDC, the windows 7 system can see the printrboard when it's plugged in, and [BootLoaderCDC]Teensylu/Printrboard is setup in the arduinio gui for the 'Board' type. When I try to compile I get the following error.
gcode.cpp: In member function 'virtual size_t SerialOutput::write(uint8_t)':
gcode.cpp:405: error: 'Serial' was not declared in this scope
gcode.cpp: In function 'void gcode_resend()':
gcode.cpp:511: error: 'Serial' was not declared in this scope
gcode.cpp: In function 'void gcode_read_serial()':
gcode.cpp:670: error: 'Serial' was not declared in this scope
gcode.cpp:682: error: 'Serial' was not declared in this scope
Anyone have an idea of what I missed?
Thanks,
./Drae
Use Teensyduino to compile. The Teensy++ 2.0 board profile is compatible with the Printrboard, but you'll have to manually invoke avrdude or edit the boards.txt in order to program with the CDC bootloader.
