Compile and upload with Eclipse?
March 02, 2013 11:35PM
Can anyone give me directions on how to compile and upload teacup firmware (mainly Cyberwizzard's lookahead version) with eclipse instead of Arduino?
Re: Compile and upload with Eclipse?
March 03, 2013 06:52AM
Use Eclipse as a text editor only and "make" or "make program" from the command line. Eclipse is waaay to complex for my taste.
March 03, 2013 08:03PM
Ahh, ok. I also can't figure out how to do the make/makefile thing as I have Windows 7. I'm starting to think I need to install a copy of Linux in a virtual machine to do this firmware stuff!
March 04, 2013 03:06AM
You're right. The only way to make Windows a decent open source development machine is to install Linux, a BSD, or at least all the development stuff from Linux (make, avr-libc, avr-gcc).
March 04, 2013 11:36AM
This peaks my interest in learning how to push compiled software from the command line. I've done it once but that was kind of a step-by-step kinda thing and I didn't take notes.
Linux is friendly for doing that, where as on Windows yes you end up installing LOADS of development tools, just to get at a single file you may need to compile something.
March 04, 2013 02:19PM
If for some reason you don't want to use the Arduino IDE, the tools to build and download are still available at the command line. Instead of Arduino, you could use the WinAVR package, which is what I used for AVR programming. There are web articles about how to use Eclipse for AVR programming, some people love it, though personally I am not a fan of Eclipse.
Then there is also the Atmel Studio.
Linux is great, but seems like overkill just to get an AVR programming environment. Generally, AVR projects are pretty simple and don't require all the tools that Linux provides.
March 04, 2013 05:30PM
Can WinAVR replace Arduino IDE?
March 04, 2013 06:08PM
Sure, there is nothing special about the Arduino IDE. [www.youtube.com]
Arduino just provides a convenient package of editor, compiler, downloader, tailored for particular MCU boards, but you can do all those with any other setup. The Arduino libraries are all open source, so there is no problem building outside Arduino.
Teacup has minimal dependencies on Arduino, so is very easy to build outside Arduino.
March 05, 2013 09:57PM
I get this bunch of output when I try and compile with WinAVR and PN
> "make.exe" all
rm -f build/depend
mkdir -p build
avr-gcc -DF_CPU=20000000L -mmcu=atmega644p -g -Wall -Wstrict-prototypes -std=gnu99 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums -Winline -fno-move-loop-invariants -fno-tree-scev-cprop -Os -ffunction-sections -finline-functions-called-once -mcall-prologues -save-temps=obj -MM analog.c clock.c copier.c crc.c dda.c dda_lookahead.c dda_maths.c dda_queue.c debug.c delay.c gcode_parse.c gcode_process.c graycode.c heater.c home.c intercom.c mendel.c pinio.c sd.c serial.c sermsg.c sersendf.c temp.c timer.c usb_serial.c watchdog.c > build/depend
avr-gcc.exe: unrecognized option '-save-temps=obj'
  CC        build/analog.o
avr-gcc: unrecognized option '-save-temps=obj'
  CC        build/clock.o
  CC        build/copier.o
  CC        build/crc.o
  CC        build/dda.o
  CC        build/dda_lookahead.o
  CC        build/dda_maths.o
  CC        build/dda_queue.o
  CC        build/debug.o
  CC        build/delay.o
  CC        build/gcode_parse.o
  CC        build/gcode_process.o
  CC        build/graycode.o
  CC        build/heater.o
  CC        build/home.o
  CC        build/intercom.o
  CC        build/mendel.o
  CC        build/pinio.o
  CC        build/sd.o
  CC        build/serial.o
  CC        build/sermsg.o
  CC        build/sersendf.o
  CC        build/temp.o
  CC        build/timer.o
  CC        build/usb_serial.o
  CC        build/watchdog.o
  LINK      build/teacup.elf
  OBJCOPY   teacup.hex
  OBJDUMP   build/teacup.lst
  SYM       build/teacup.sym
/usr/bin/sh: perl: command not found
    SIZES             ATmega...  '168    '328(P)    '644(P)    '1280
make.exe: ***  Error 127
> Process Exit Code: 2
> Time Taken: 00:19
Any hints to make it work?
I'm trying the compile Cyberwizzard's teacup (the one with look ahead)
March 05, 2013 10:42PM
> with WinAVR and PN
> CC build/analog.o
That seems to be a relatively new compiler option that is not supported. It shouldn't affect the build.
> '644(P) '1280
The makefile uses some perl commands to post-process some informational output, shouldn't affect build either.
Despite the error message, it probably has worked, you should find a .bin or .hex file in the build directory.
March 09, 2013 08:58PM
Using the Programmer's Notepad that came with WinAVR I managed to upload it using the WinAVR tools that are preinstalled in PN. I had to change the linux path to the USB to the Windows recognised COM4, but it worked after that. Thanks!
