SoftwareSerial.h with Marlin
Posted by chik
August 01, 2013 10:58AM
Hi everybody,
I want to use an RFID module to my mega 2560!!
For this, I write a program which used SoftwareSerial.h, and it works fine!!
When I add it to Marlin, I cannot connect my boardto pronterface " I think I have a bug".
I have this configuration :
#define rxPin 50
#define txPin 24
SoftwareSerial rfserial(rxPin, txPin);
If I omit the line SoftwareSerial rfserial(rxPin, txPin); my Marlin works fine.
If I omit Marlin, and I use read and write program, it works fine!!!
Please help, I spend a lot of time on it!!!!
Re: SoftwareSerial.h with Marlin
August 01, 2013 12:23PM
why are you using soft serial? there are 3 hardware serial ports on the atmega 2560. the latest version of marlin also allows you to choose which port it runs from.
here is a version that allows you to use usb and serial chip as well as bt communication together, although it loads sd card at 1/4th the speed
[bitbucket.org]
August 01, 2013 01:13PM
OK!!
I want to connect my mega to main serial port for pronterface!!
And connectiing another serial port to my RFID module, but it bugs!!
my second serial port is defined as software serial and it works!!
and when I add Marlin, I cannot connect my board to pronterface!!
That is my problem, and I don't know what is the solution!!
Please help!!
August 01, 2013 08:19PM
change marlin version to the one i mention in the link. it allows 2 serial communications at the same time. both are hardware.
August 02, 2013 04:00AM
Ok, I will check that!!
SoftwareSerial HardwareSerial with Marlin
August 02, 2013 05:36AM
Hi jamesdanielv,
I dowloaded the new marlin, and I added this code :
case 1000: //M1000 Turn on the Led's RFID Module
byte LedOn[5] ={0xBA,0x03,0x40,0x01,0xF8};
for (int i =0; i< 5; i++){
Seria2l.write(LedOn);
And it said that Serial2 was not declared in the scope!!
It is the same error!!!!
Do I have to change something in MarlinSerial?!
August 02, 2013 11:10AM
check your typing. there is an error in your defined serial command.
August 02, 2013 12:01PM
In the setup, I add Serial2.begin(9600); !!
August 02, 2013 12:18PM
I don't know, where is the error!!
Please could you check this in your project, and add Serial2.write("Y"); into a new gcode for exemple "m1000".
Think you
August 02, 2013 01:19PM
Any results?!!
Please help!!
August 02, 2013 05:12PM
first check for typo's
Serial2.write(LedOn);
August 02, 2013 05:13PM
can you list your entire code?
August 03, 2013 09:02AM
Hi jamesdanielv,
Think you for response!!
Please fond here my program "Marlin.cpp"
/* -*- c++ -*- */
Reprap firmware based on Sprinter and grbl.
Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see [www.gnu.org].
This firmware is a mashup between Sprinter and grbl.
(https://github.com/kliment/Sprinter)
(https://github.com/simen/grbl/tree)
It has preliminary support for Matthew Roberts advance algorithm
[reprap.org]
#include "Marlin.h"
#include "ultralcd.h"
#include "planner.h"
#include "stepper.h"
#include "temperature.h"
#include "motion_control.h"
#include "cardreader.h"
#include "watchdog.h"
#include "EEPROMwrite.h"
#include "language.h"
#include "pins_arduino.h"
#define VERSION_STRING "1.0.0"
// look here for descriptions of gcodes: [linuxcnc.org]
// [objects.reprap.org]
//Implemented Codes
// G0 -> G1
// G1 - Coordinated Movement X Y Z E
// G2 - CW ARC
// G3 - CCW ARC
// G4 - Dwell S or P
// G10 - retract filament according to settings of M207
// G11 - retract recover filament according to settings of M208
// G28 - Home all Axis
// G90 - Use Absolute Coordinates
// G91 - Use Relative Coordinates
// G92 - Set current position to cordinates given
//RepRap M Codes
// M0 - Unconditional stop - Wait for user to press a button on the LCD (Only if ULTRA_LCD is enabled)
// M1 - Same as M0
// M104 - Set extruder target temp
// M105 - Read current temp
// M106 - Fan on
// M107 - Fan off
// M109 - Wait for extruder current temp to reach target temp.
// M114 - Display current position
//Custom M Codes
// M17 - Enable/Power all stepper motors
// M18 - Disable all stepper motors; same as M84
// M20 - List SD card
// M21 - Init SD card
// M22 - Release SD card
// M23 - Select SD file (M23 filename.g)
// M24 - Start/resume SD print
// M25 - Pause SD print
// M26 - Set SD position in bytes (M26 S12345)
// M27 - Report SD print status
// M28 - Start SD write (M28 filename.g)
// M29 - Stop SD write
// M30 - Delete file from SD (M30 filename.g)
// M31 - Output time since last M109 or SD card start to serial
// M42 - Change pin status via gcode
// M80 - Turn on Power Supply
// M81 - Turn off Power Supply
// M82 - Set E codes absolute (default)
// M83 - Set E codes relative while in Absolute Coordinates (G90) mode
// M84 - Disable steppers until next move,
// or use S to specify an inactivity timeout, after which the steppers will be disabled. S0 to disable the timeout.
// M85 - Set inactivity shutdown timer with parameter S. To disable set zero (default)
// M92 - Set axis_steps_per_unit - same syntax as G92
// M114 - Output current position to serial port
// M115 - Capabilities string
// M117 - display message
// M119 - Output Endstop status to serial port
// M140 - Set bed target temp
// M190 - Wait for bed current temp to reach target temp.
// M200 - Set filament diameter
// M201 - Set max acceleration in units/s^2 for print moves (M201 X1000 Y1000)
// M202 - Set max acceleration in units/s^2 for travel moves (M202 X1000 Y1000) Unused in Marlin!!
// M203 - Set maximum feedrate that your machine can sustain (M203 X200 Y200 Z300 E10000) in mm/sec
// M204 - Set default acceleration: S normal moves T filament only moves (M204 S3000 T7000) im mm/sec^2 also sets minimum segment time in ms (B20000) to prevent buffer underruns and M20 minimum feedrate
// M205 - advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk, E=maximum E jerk
// M206 - set additional homeing offset
// M207 - set retract length S[positive mm] F[feedrate mm/sec] Z[additional zlift/hop]
// M208 - set recover=unretract length S[positive mm surplus to the M207 S*] F[feedrate mm/sec]
// M209 - S<1=true/0=false> enable automatic retract detect if the slicer did not support G10/11: every normal extrude-only move will be classified as retract depending on the direction.
// M220 S- set speed factor override percentage
// M221 S- set extrude factor override percentage
// M240 - Trigger a camera to take a photograph
// M301 - Set PID parameters P I and D
// M302 - Allow cold extrudes
// M303 - PID relay autotune S sets the target temperature. (default target temperature = 150C)
// M400 - Finish all moves
// M500 - stores paramters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to.
// M503 - print the current settings (from memory not from eeprom)
// M999 - Restart after being stopped by error
//Stepper Movement Variables
//=============================imported variables============================
//=============================public variables=============================
#ifdef SDSUPPORT
CardReader card;
#endif
float homing_feedrate[] = HOMING_FEEDRATE;
bool axis_relative_modes[] = AXIS_RELATIVE_MODES;
volatile int feedmultiply=100; //100->1 200->2
int saved_feedmultiply;
volatile bool feedmultiplychanged=false;
volatile int extrudemultiply=100; //100->1 200->2
float current_position[NUM_AXIS] = { 0.0, 0.0, 0.0, 0.0 };
float add_homeing[3]={0,0,0};
float min_pos[3] = { X_MIN_POS, Y_MIN_POS, Z_MIN_POS };
float max_pos[3] = { X_MAX_POS, Y_MAX_POS, Z_MAX_POS };
uint8_t active_extruder = 0;
unsigned char FanSpeed=0;
#ifdef FWRETRACT
bool autoretract_enabled=true;
bool retracted=false;
float retract_length=3, retract_feedrate=17*60, retract_zlift=0.8;
float retract_recover_length=0, retract_recover_feedrate=8*60;
#endif
//=============================private variables=============================
const char axis_codes[NUM_AXIS] = {'X', 'Y', 'Z', 'E'};
static float destination[NUM_AXIS] = { 0.0, 0.0, 0.0, 0.0};
static float offset[3] = {0.0, 0.0, 0.0};
static bool home_all_axis = true;
static float feedrate = 1500.0, next_feedrate, saved_feedrate;
static long gcode_N, gcode_LastN, Stopped_gcode_LastN = 0;
static bool relative_mode = false; //Determines Absolute or Relative Coordinates
static bool relative_mode_e = false; //Determines Absolute or Relative E Codes while in Absolute Coordinates mode. E is always relative in Relative Coordinates mode.
static char cmdbuffer[BUFSIZE][MAX_CMD_SIZE];
static bool fromsd[BUFSIZE];
static int bufindr = 0;
static int bufindw = 0;
static int buflen = 0;
//static int i = 0;
static char serial_char;
static int serial_count = 0;
static boolean comment_mode = false;
static char *strchr_pointer; // just a pointer to find chars in the cmd string like X, Y, Z, E, etc
const int sensitive_pins[] = SENSITIVE_PINS; // Sensitive pin list for M42
//static float tt = 0;
//static float bt = 0;
//Inactivity shutdown variables
static unsigned long previous_millis_cmd = 0;
static unsigned long max_inactive_time = 0;
static unsigned long stepper_inactive_time = DEFAULT_STEPPER_DEACTIVE_TIME*1000l;
static unsigned long starttime=0;
static unsigned long stoptime=0;
static uint8_t tmp_extruder;
bool Stopped=false;
//=============================ROUTINES=============================
void get_arc_coordinates();
bool setTargetedHotend(int code);
void serial_echopair_P(const char *s_P, float v)
{ serialprintPGM(s_P); SERIAL_ECHO(v); }
void serial_echopair_P(const char *s_P, double v)
void serial_echopair_P(const char *s_P, unsigned long v)
extern "C"{
extern unsigned int __bss_end;
extern unsigned int __heap_start;
extern void *__brkval;
int freeMemory() {
int free_memory;
if((int)__brkval == 0)
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
//adds an command to the main command buffer
//thats really done in a non-safe way.
//needs overworking someday
void enquecommand(const char *cmd)
if(buflen < BUFSIZE)
//this is dangerous if a mixing of serial and this happsens
strcpy(&(cmdbuffer[bufindw][0]),cmd);
SERIAL_ECHO_START;
SERIAL_ECHOPGM("enqueing \"");
SERIAL_ECHO(cmdbuffer[bufindw]);
SERIAL_ECHOLNPGM("\"");
bufindw= (bufindw + 1)%BUFSIZE;
buflen += 1;
void setup_killpin()
#if( KILL_PIN>-1 )
pinMode(KILL_PIN,INPUT);
WRITE(KILL_PIN,HIGH);
#endif
void setup_photpin()
#ifdef PHOTOGRAPH_PIN
#if (PHOTOGRAPH_PIN > -1)
SET_OUTPUT(PHOTOGRAPH_PIN);
WRITE(PHOTOGRAPH_PIN, LOW);
#endif
#endif
void setup_powerhold()
#ifdef SUICIDE_PIN
#if (SUICIDE_PIN> -1)
SET_OUTPUT(SUICIDE_PIN);
WRITE(SUICIDE_PIN, HIGH);
#endif
#endif
void suicide()
#ifdef SUICIDE_PIN
WRITE(SUICIDE_PIN, LOW);
#endif
#endif
void setup()
setup_killpin();
setup_powerhold();
MYSERIAL.begin(BAUDRATE);
Serial2.begin(BAUDRATE);
SERIAL_PROTOCOLLNPGM("start");
SERIAL_ECHO_START;
// Check startup - does nothing if bootloader sets MCUSR to 0
byte mcu = MCUSR;
if(mcu & 1) SERIAL_ECHOLNPGM(MSG_POWERUP);
if(mcu & 2) SERIAL_ECHOLNPGM(MSG_EXTERNAL_RESET);
if(mcu & 4) SERIAL_ECHOLNPGM(MSG_BROWNOUT_RESET);
if(mcu & 8) SERIAL_ECHOLNPGM(MSG_WATCHDOG_RESET);
if(mcu & 32) SERIAL_ECHOLNPGM(MSG_SOFTWARE_RESET);
MCUSR=0;
SERIAL_ECHOPGM(MSG_MARLIN);
SERIAL_ECHOLNPGM(VERSION_STRING);
#ifdef STRING_VERSION_CONFIG_H
#ifdef STRING_CONFIG_H_AUTHOR
SERIAL_ECHO_START;
SERIAL_ECHOPGM(MSG_CONFIGURATION_VER);
SERIAL_ECHOPGM(STRING_VERSION_CONFIG_H);
SERIAL_ECHOPGM(MSG_AUTHOR);
SERIAL_ECHOLNPGM(STRING_CONFIG_H_AUTHOR);
#endif
#endif
SERIAL_ECHO_START;
SERIAL_ECHOPGM(MSG_FREE_MEMORY);
SERIAL_ECHO(freeMemory());
SERIAL_ECHOPGM(MSG_PLANNER_BUFFER_BYTES);
SERIAL_ECHOLN((int)sizeof(block_t)*BLOCK_BUFFER_SIZE);
for(int8_t i = 0; i < BUFSIZE; i++)
fromsd = false;
EEPROM_RetrieveSettings(); // loads data from EEPROM if available
for(int8_t i=0; i < NUM_AXIS; i++)
axis_steps_per_sqr_second = max_acceleration_units_per_sq_second * axis_steps_per_unit;
tp_init(); // Initialize temperature loop
plan_init(); // Initialize planner;
st_init(); // Initialize stepper;
wd_init();
setup_photpin();
LCD_INIT;
void loop()
if(buflen < (BUFSIZE-1))
get_command();
#ifdef SDSUPPORT
card.checkautostart(false);
#endif
if(buflen)
#ifdef SDSUPPORT
if(card.saving)
if(strstr(cmdbuffer[bufindr],"M29") == NULL)
card.write_command(cmdbuffer[bufindr]);
SERIAL_PROTOCOLLNPGM(MSG_OK);
else
card.closefile();
SERIAL_PROTOCOLLNPGM(MSG_FILE_SAVED);
else
process_commands();
#else
process_commands();
#endif //SDSUPPORT
buflen = (buflen-1);
bufindr = (bufindr + 1)%BUFSIZE;
//check heater every n milliseconds
manage_heater();
manage_inactivity();
checkHitEndstops();
LCD_STATUS;
void get_command()
while( MYSERIAL.available() > 0 && buflen < BUFSIZE) {
serial_char = MYSERIAL.read();
if(serial_char == '\n' ||
serial_char == '\r' ||
(serial_char == ':' && comment_mode == false) ||
serial_count >= (MAX_CMD_SIZE - 1) )
if(!serial_count) { //if empty line
comment_mode = false; //for new command
return;
cmdbuffer[bufindw][serial_count] = 0; //terminate string
if(!comment_mode){
fromsd[bufindw] = false;
if(strstr(cmdbuffer[bufindw], "N") != NULL)
strchr_pointer = strchr(cmdbuffer[bufindw], 'N');
gcode_N = (strtol(&cmdbuffer[bufindw][strchr_pointer - cmdbuffer[bufindw] + 1], NULL, 10));
if(gcode_N != gcode_LastN+1 && (strstr(cmdbuffer[bufindw], "M110") == NULL) ) {
SERIAL_ERROR_START;
SERIAL_ERRORPGM(MSG_ERR_LINE_NO);
SERIAL_ERRORLN(gcode_LastN);
//Serial.println(gcode_N);
FlushSerialRequestResend();
serial_count = 0;
return;
if(strstr(cmdbuffer[bufindw], "*") != NULL)
byte checksum = 0;
byte count = 0;
while(cmdbuffer[bufindw][count] != '*') checksum = checksum^cmdbuffer[bufindw][count++];
strchr_pointer = strchr(cmdbuffer[bufindw], '*');
if( (int)(strtod(&cmdbuffer[bufindw][strchr_pointer - cmdbuffer[bufindw] + 1], NULL)) != checksum) {
SERIAL_ERROR_START;
SERIAL_ERRORPGM(MSG_ERR_CHECKSUM_MISMATCH);
serial_count = 0;
return;
//if no errors, continue parsing
else
SERIAL_ERROR_START;
SERIAL_ERRORPGM(MSG_ERR_NO_CHECKSUM);
serial_count = 0;
return;
gcode_LastN = gcode_N;
else // if we don't receive 'N' but still see '*'
if((strstr(cmdbuffer[bufindw], "*") != NULL))
SERIAL_ERROR_START;
SERIAL_ERRORPGM(MSG_ERR_NO_LINENUMBER_WITH_CHECKSUM);
serial_count = 0;
return;
if((strstr(cmdbuffer[bufindw], "G") != NULL)){
strchr_pointer = strchr(cmdbuffer[bufindw], 'G');
switch((int)((strtod(&cmdbuffer[bufindw][strchr_pointer - cmdbuffer[bufindw] + 1], NULL)))){
case 0:
case 1:
case 2:
case 3:
if(Stopped == false) { // If printer is stopped by an error the G[0-3] codes are ignored.
#ifdef SDSUPPORT
if(card.saving)
break;
#endif //SDSUPPORT
else {
SERIAL_ERRORLNPGM(MSG_ERR_STOPPED);
LCD_MESSAGEPGM(MSG_STOPPED);
break;
default:
break;
bufindw = (bufindw + 1)%BUFSIZE;
buflen += 1;
serial_count = 0; //clear buffer
else
if(serial_char == ';') comment_mode = true;
if(!comment_mode) cmdbuffer[bufindw][serial_count++] = serial_char;
#ifdef SDSUPPORT
if(!card.sdprinting || serial_count!=0){
return;
while( !card.eof() && buflen < BUFSIZE) {
int16_t n=card.get();
serial_char = (char)n;
serial_count >= (MAX_CMD_SIZE - 1)||n==-1)
if(card.eof()){
SERIAL_PROTOCOLLNPGM(MSG_FILE_PRINTED);
stoptime=millis();
char time[30];
unsigned long t=(stoptime-starttime)/1000;
int sec,min;
min=t/60;
sec=t%60;
sprintf(time,"%i min, %i sec",min,sec);
SERIAL_ECHO_START;
SERIAL_ECHOLN(time);
LCD_MESSAGE(time);
card.printingHasFinished();
card.checkautostart(true);
if(!serial_count)
return; //if empty line
// if(!comment_mode){
fromsd[bufindw] = true;
buflen += 1;
else
#endif //SDSUPPORT
float code_value()
return (strtod(&cmdbuffer[bufindr][strchr_pointer - cmdbuffer[bufindr] + 1], NULL));
long code_value_long()
return (strtol(&cmdbuffer[bufindr][strchr_pointer - cmdbuffer[bufindr] + 1], NULL, 10));
bool code_seen(char code_string[]) //Return True if the string was found
return (strstr(cmdbuffer[bufindr], code_string) != NULL);
bool code_seen(char code)
strchr_pointer = strchr(cmdbuffer[bufindr], code);
return (strchr_pointer != NULL); //Return True if a character was found
#define DEFINE_PGM_READ_ANY(type, reader) \
static inline type pgm_read_any(const type *p) \
{ return pgm_read_##reader##_near(p); }
DEFINE_PGM_READ_ANY(float, float);
DEFINE_PGM_READ_ANY(signed char, byte);
#define XYZ_CONSTS_FROM_CONFIG(type, array, CONFIG) \
static const PROGMEM type array##_P[3] = \
{ X_##CONFIG, Y_##CONFIG, Z_##CONFIG }; \
static inline type array(int axis) \
{ return pgm_read_any(&array##_P[axis]); }
XYZ_CONSTS_FROM_CONFIG(float, base_min_pos, MIN_POS);
XYZ_CONSTS_FROM_CONFIG(float, base_max_pos, MAX_POS);
XYZ_CONSTS_FROM_CONFIG(float, base_home_pos, HOME_POS);
XYZ_CONSTS_FROM_CONFIG(float, max_length, MAX_LENGTH);
XYZ_CONSTS_FROM_CONFIG(float, home_retract_mm, HOME_RETRACT_MM);
XYZ_CONSTS_FROM_CONFIG(signed char, home_dir, HOME_DIR);
static void axis_is_at_home(int axis) {
current_position[axis] = base_home_pos(axis) + add_homeing[axis];
min_pos[axis] = base_min_pos(axis) + add_homeing[axis];
max_pos[axis] = base_max_pos(axis) + add_homeing[axis];
static void homeaxis(int axis) {
#define HOMEAXIS_DO(LETTER) \
((LETTER##_MIN_PIN > -1 && LETTER##_HOME_DIR==-1) || (LETTER##_MAX_PIN > -1 && LETTER##_HOME_DIR==1))
if (axis==X_AXIS ? HOMEAXIS_DO(X) :
axis==Y_AXIS ? HOMEAXIS_DO(Y) :
axis==Z_AXIS ? HOMEAXIS_DO(Z) :
0) {
current_position[axis] = 0;
plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]);
destination[axis] = 1.5 * max_length(axis) * home_dir(axis);
feedrate = homing_feedrate[axis];
plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate/60, active_extruder);
st_synchronize();
destination[axis] = -home_retract_mm(axis) * home_dir(axis);
st_synchronize();
destination[axis] = 2*home_retract_mm(axis) * home_dir(axis);
feedrate = homing_feedrate[axis]/2 ;
st_synchronize();
axis_is_at_home(axis);
destination[axis] = current_position[axis];
feedrate = 0.0;
endstops_hit_on_purpose();
#define HOMEAXIS(LETTER) homeaxis(LETTER##_AXIS)
void process_commands()
unsigned long codenum; //throw away variable
char *starpos = NULL;
if(code_seen('G'))
switch((int)code_value())
case 0: // G0 -> G1
case 1: // G1
get_coordinates(); // For X Y Z E F
prepare_move();
//ClearToSend();
return;
//break;
case 2: // G2 - CW ARC
prepare_arc_move(true);
return;
case 3: // G3 - CCW ARC
prepare_arc_move(false);
return;
case 4: // G4 dwell
LCD_MESSAGEPGM(MSG_DWELL);
codenum = 0;
if(code_seen('P')) codenum = code_value(); // milliseconds to wait
if(code_seen('S')) codenum = code_value() * 1000; // seconds to wait
st_synchronize();
codenum += millis(); // keep track of when we started waiting
previous_millis_cmd = millis();
while(millis() < codenum ){
manage_heater();
LCD_STATUS;
break;
#ifdef FWRETRACT
case 10: // G10 retract
if(!retracted)
destination[X_AXIS]=current_position[X_AXIS];
destination[Y_AXIS]=current_position[Y_AXIS];
destination[Z_AXIS]=current_position[Z_AXIS];
current_position[Z_AXIS]+=-retract_zlift;
destination[E_AXIS]=current_position[E_AXIS]-retract_length;
feedrate=retract_feedrate;
retracted=true;
prepare_move();
break;
case 11: // G10 retract_recover
if(!retracted)
current_position[Z_AXIS]+=retract_zlift;
current_position[E_AXIS]+=-retract_recover_length;
feedrate=retract_recover_feedrate;
retracted=false;
prepare_move();
break;
#endif //FWRETRACT
case 28: //G28 Home all Axis one at a time
saved_feedrate = feedrate;
saved_feedmultiply = feedmultiply;
feedmultiply = 100;
enable_endstops(true);
for(int8_t i=0; i < NUM_AXIS; i++) {
destination = current_position;
feedrate = 0.0;
home_all_axis = !((code_seen(axis_codes[0])) || (code_seen(axis_codes[1])) || (code_seen(axis_codes[2])));
#if Z_HOME_DIR > 0 // If homing away from BED do Z first
if((home_all_axis) || (code_seen(axis_codes[Z_AXIS]))) {
HOMEAXIS(Z);
#endif
#ifdef QUICK_HOME
if((home_all_axis)||( code_seen(axis_codes[X_AXIS]) && code_seen(axis_codes[Y_AXIS])) ) //first diagonal move
current_position[X_AXIS] = 0;current_position[Y_AXIS] = 0;
destination[X_AXIS] = 1.5 * X_MAX_LENGTH * X_HOME_DIR;destination[Y_AXIS] = 1.5 * Y_MAX_LENGTH * Y_HOME_DIR;
feedrate = homing_feedrate[X_AXIS];
if(homing_feedrate[Y_AXIS] 0){
while(millis() < codenum && !CLICKED){
manage_heater();
LCD_STATUS;
}else{
while(!CLICKED){
manage_heater();
LCD_STATUS;
break;
#endif
case 17:
LCD_MESSAGEPGM(MSG_NO_MOVE);
enable_x();
enable_y();
enable_z();
enable_e0();
enable_e1();
enable_e2();
break;
#ifdef SDSUPPORT
case 20: // M20 - list SD card
SERIAL_PROTOCOLLNPGM(MSG_BEGIN_FILE_LIST);
card.ls();
SERIAL_PROTOCOLLNPGM(MSG_END_FILE_LIST);
break;
case 21: // M21 - init SD card
card.initsd();
break;
case 22: //M22 - release SD card
card.release();
break;
case 23: //M23 - Select file
starpos = (strchr(strchr_pointer + 4,'*'));
if(starpos!=NULL)
*(starpos-1)='\0';
card.openFile(strchr_pointer + 4,true);
break;
case 24: //M24 - Start SD print
card.startFileprint();
starttime=millis();
break;
case 25: //M25 - Pause SD print
card.pauseSDPrint();
break;
case 26: //M26 - Set SD index
if(card.cardOK && code_seen('S')) {
card.setIndex(code_value_long());
break;
case 27: //M27 - Get SD status
card.getStatus();
break;
case 28: //M28 - Start SD write
if(starpos != NULL){
char* npos = strchr(cmdbuffer[bufindr], 'N');
strchr_pointer = strchr(npos,' ') + 1;
*(starpos-1) = '\0';
card.openFile(strchr_pointer+4,false);
break;
case 29: //M29 - Stop SD write
//processed in write to file routine above
//card,saving = false;
break;
case 30: //M30 Delete File
if (card.cardOK){
card.closefile();
card.removeFile(strchr_pointer + 4);
break;
#endif //SDSUPPORT
case 31: //M31 take time since the start of the SD print or an M109 command
stoptime=millis();
char time[30];
int sec,min;
min=t/60;
sec=t%60;
SERIAL_ECHO_START;
LCD_MESSAGE(time);
autotempShutdown();
break;
case 42: //M42 -Change pin status via gcode
if (code_seen('S'))
int pin_status = code_value();
if (code_seen('P') && pin_status >= 0 && pin_status <= 255)
int pin_number = code_value();
for(int8_t i = 0; i < (int8_t)sizeof(sensitive_pins); i++)
if (sensitive_pins == pin_number)
pin_number = -1;
break;
if (pin_number > -1)
pinMode(pin_number, OUTPUT);
digitalWrite(pin_number, pin_status);
analogWrite(pin_number, pin_status);
break;
case 104: // M104
if(setTargetedHotend(104)){
break;
if (code_seen('S')) setTargetHotend(code_value(), tmp_extruder);
setWatch();
break;
case 140: // M140 set bed temp
if (code_seen('S')) setTargetBed(code_value());
break;
case 105 : // M105
if(setTargetedHotend(105)){
break;
#if (TEMP_0_PIN > -1)
SERIAL_PROTOCOLPGM("ok T:");
SERIAL_PROTOCOL_F(degHotend(tmp_extruder),1);
SERIAL_PROTOCOLPGM(" /");
SERIAL_PROTOCOL_F(degTargetHotend(tmp_extruder),1);
#if TEMP_BED_PIN > -1
SERIAL_PROTOCOLPGM(" B:");
SERIAL_PROTOCOL_F(degBed(),1);
SERIAL_PROTOCOL_F(degTargetBed(),1);
#endif //TEMP_BED_PIN
#else
SERIAL_ERROR_START;
SERIAL_ERRORLNPGM(MSG_ERR_NO_THERMISTORS);
#endif
#ifdef PIDTEMP
SERIAL_PROTOCOLPGM(" @:");
SERIAL_PROTOCOL(getHeaterPower(tmp_extruder));
#endif
SERIAL_PROTOCOLLN("");
return;
break;
case 109:
{// M109 - Wait for extruder heater to reach target.
if(setTargetedHotend(109)){
break;
LCD_MESSAGEPGM(MSG_HEATING);
#ifdef AUTOTEMP
autotemp_enabled=false;
#endif
#ifdef AUTOTEMP
if (code_seen('S')) autotemp_min=code_value();
if (code_seen('B')) autotemp_max=code_value();
if (code_seen('F'))
autotemp_factor=code_value();
autotemp_enabled=true;
#endif
setWatch();
codenum = millis();
/* See if we are heating up or cooling down */
bool target_direction = isHeatingHotend(tmp_extruder); // true if heating, false if cooling
#ifdef TEMP_RESIDENCY_TIME
long residencyStart;
residencyStart = -1;
/* continue to loop until we have reached the target temp
_and_ until TEMP_RESIDENCY_TIME hasn't passed since we reached it */
while((residencyStart == -1) ||
(residencyStart >= 0 && (((unsigned int) (millis() - residencyStart)) < (TEMP_RESIDENCY_TIME * 1000UL))) ) {
#else
while ( target_direction ? (isHeatingHotend(tmp_extruder)) : (isCoolingHotend(tmp_extruder)&&(CooldownNoWait==false)) ) {
#endif //TEMP_RESIDENCY_TIME
if( (millis() - codenum) > 1000UL )
{ //Print Temp Reading and remaining time every 1 second while heating up/cooling down
SERIAL_PROTOCOLPGM("T:");
SERIAL_PROTOCOLPGM(" E:");
SERIAL_PROTOCOL((int)tmp_extruder);
SERIAL_PROTOCOLPGM(" W:");
if(residencyStart > -1)
codenum = ((TEMP_RESIDENCY_TIME * 1000UL) - (millis() - residencyStart)) / 1000UL;
SERIAL_PROTOCOLLN( codenum );
else
SERIAL_PROTOCOLLN( "?" );
#else
#endif
codenum = millis();
manage_heater();
LCD_STATUS;
/* start/restart the TEMP_RESIDENCY_TIME timer whenever we reach target temp for the first time
or when current temp falls outside the hysteresis after target temp was reached */
if ((residencyStart == -1 && target_direction && (degHotend(tmp_extruder) >= (degTargetHotend(tmp_extruder)-TEMP_WINDOW))) ||
(residencyStart == -1 && !target_direction && (degHotend(tmp_extruder) <= (degTargetHotend(tmp_extruder)+TEMP_WINDOW))) ||
(residencyStart > -1 && labs(degHotend(tmp_extruder) - degTargetHotend(tmp_extruder)) > TEMP_HYSTERESIS) )
residencyStart = millis();
LCD_MESSAGEPGM(MSG_HEATING_COMPLETE);
starttime=millis();
break;
case 190: // M190 - Wait for bed heater to reach target.
LCD_MESSAGEPGM(MSG_BED_HEATING);
codenum = millis();
while(isHeatingBed())
if(( millis() - codenum) > 1000 ) //Print Temp Reading every 1 second while heating up.
float tt=degHotend(active_extruder);
SERIAL_PROTOCOL(tt);
SERIAL_PROTOCOL((int)active_extruder);
codenum = millis();
manage_heater();
LCD_STATUS;
LCD_MESSAGEPGM(MSG_BED_DONE);
#endif
break;
#if FAN_PIN > -1
case 106: //M106 Fan On
if (code_seen('S')){
FanSpeed=constrain(code_value(),0,255);
else {
FanSpeed=255;
break;
case 107: //M107 Fan Off
FanSpeed = 0;
break;
#endif //FAN_PIN
#if (PS_ON_PIN > -1)
case 80: // M80 - ATX Power On
SET_OUTPUT(PS_ON_PIN); //GND
WRITE(PS_ON_PIN, LOW);
break;
#endif
case 81: // M81 - ATX Power Off
#if defined SUICIDE_PIN && SUICIDE_PIN > -1
st_synchronize();
suicide();
#elif (PS_ON_PIN > -1)
WRITE(PS_ON_PIN, HIGH);
#endif
break;
case 82:
axis_relative_modes[3] = false;
break;
case 83:
axis_relative_modes[3] = true;
break;
case 18: //compatibility
case 84: // M84
if(code_seen('S')){
stepper_inactive_time = code_value() * 1000;
else
bool all_axis = !((code_seen(axis_codes[0])) || (code_seen(axis_codes[1])) || (code_seen(axis_codes[2]))|| (code_seen(axis_codes[3])));
if(all_axis)
st_synchronize();
disable_e0();
disable_e1();
disable_e2();
finishAndDisableSteppers();
else
st_synchronize();
if(code_seen('X')) disable_x();
if(code_seen('Y')) disable_y();
if(code_seen('Z')) disable_z();
#if ((E0_ENABLE_PIN != X_ENABLE_PIN) && (E1_ENABLE_PIN != Y_ENABLE_PIN)) // Only enable on boards that have seperate ENABLE_PINS
if(code_seen('E')) {
disable_e0();
disable_e1();
disable_e2();
#endif
LCD_MESSAGEPGM(MSG_PART_RELEASE);
break;
case 85: // M85
code_seen('S');
max_inactive_time = code_value() * 1000;
break;
case 92: // M92
if(code_seen(axis_codes))
if(i == 3) { // E
float value = code_value();
if(value < 20.0) {
float factor = axis_steps_per_unit / value; // increase e constants if M92 E14 is given for netfab.
max_e_jerk *= factor;
max_feedrate *= factor;
axis_steps_per_sqr_second *= factor;
axis_steps_per_unit = value;
else {
axis_steps_per_unit = code_value();
break;
case 115: // M115
SerialprintPGM(MSG_M115_REPORT);
break;
case 117: // M117 display message
LCD_MESSAGE(cmdbuffer[bufindr]+5);
break;
case 114: // M114
SERIAL_PROTOCOLPGM("X:");
SERIAL_PROTOCOL(current_position[X_AXIS]);
SERIAL_PROTOCOLPGM("Y:");
SERIAL_PROTOCOL(current_position[Y_AXIS]);
SERIAL_PROTOCOLPGM("Z:");
SERIAL_PROTOCOL(current_position[Z_AXIS]);
SERIAL_PROTOCOLPGM("E:");
SERIAL_PROTOCOL(current_position[E_AXIS]);
SERIAL_PROTOCOLPGM(MSG_COUNT_X);
SERIAL_PROTOCOL(float(st_get_position(X_AXIS))/axis_steps_per_unit[X_AXIS]);
SERIAL_PROTOCOL(float(st_get_position(Y_AXIS))/axis_steps_per_unit[Y_AXIS]);
SERIAL_PROTOCOL(float(st_get_position(Z_AXIS))/axis_steps_per_unit[Z_AXIS]);
break;
case 120: // M120
enable_endstops(false) ;
break;
case 121: // M121
enable_endstops(true) ;
break;
case 119: // M119
#if (X_MIN_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_X_MIN);
SERIAL_PROTOCOL(((READ(X_MIN_PIN)^X_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
#if (X_MAX_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_X_MAX);
SERIAL_PROTOCOL(((READ(X_MAX_PIN)^X_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
#if (Y_MIN_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_Y_MIN);
SERIAL_PROTOCOL(((READ(Y_MIN_PIN)^Y_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
#if (Y_MAX_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_Y_MAX);
SERIAL_PROTOCOL(((READ(Y_MAX_PIN)^Y_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
#if (Z_MIN_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_Z_MIN);
SERIAL_PROTOCOL(((READ(Z_MIN_PIN)^Z_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
#if (Z_MAX_PIN > -1)
SERIAL_PROTOCOLPGM(MSG_Z_MAX);
SERIAL_PROTOCOL(((READ(Z_MAX_PIN)^Z_ENDSTOPS_INVERTING)?"H ":"L "));
#endif
break;
//TODO: update for all axis, use for loop
case 201: // M201
max_acceleration_units_per_sq_second = code_value();
axis_steps_per_sqr_second = code_value() * axis_steps_per_unit;
break;
#if 0 // Not used for Sprinter/grbl gen6
case 202: // M202
if(code_seen(axis_codes)) axis_travel_steps_per_sqr_second = code_value() * axis_steps_per_unit;
break;
#endif
case 203: // M203 max feedrate mm/sec
if(code_seen(axis_codes)) max_feedrate = code_value();
break;
case 204: // M204 acclereration S normal moves T filmanent only moves
if(code_seen('S')) acceleration = code_value() ;
if(code_seen('T')) retract_acceleration = code_value() ;
break;
case 205: //M205 advanced settings: minimum travel speed S=while printing T=travel only, B=minimum segment time X= maximum xy jerk, Z=maximum Z jerk
if(code_seen('S')) minimumfeedrate = code_value();
if(code_seen('T')) mintravelfeedrate = code_value();
if(code_seen('B')) minsegmenttime = code_value() ;
if(code_seen('X')) max_xy_jerk = code_value() ;
if(code_seen('Z')) max_z_jerk = code_value() ;
if(code_seen('E')) max_e_jerk = code_value() ;
break;
case 206: // M206 additional homeing offset
for(int8_t i=0; i < 3; i++)
if(code_seen(axis_codes)) add_homeing = code_value();
break;
#ifdef FWRETRACT
case 207: //M207 - set retract length S[positive mm] F[feedrate mm/sec] Z[additional zlift/hop]
if(code_seen('S'))
retract_length = code_value() ;
if(code_seen('F'))
retract_feedrate = code_value() ;
if(code_seen('Z'))
retract_zlift = code_value() ;
}break;
case 208: // M208 - set retract recover length S[positive mm surplus to the M207 S*] F[feedrate mm/sec]
if(code_seen('S'))
retract_recover_length = code_value() ;
if(code_seen('F'))
retract_recover_feedrate = code_value() ;
}break;
case 209: // M209 - S<1=true/0=false> enable automatic retract detect if the slicer did not support G10/11: every normal extrude-only move will be classified as retract depending on the direction.
if(code_seen('S'))
int t= code_value() ;
switch(t)
case 0: autoretract_enabled=false;retracted=false;break;
case 1: autoretract_enabled=true;retracted=false;break;
default:
SERIAL_ECHO_START;
SERIAL_ECHOPGM(MSG_UNKNOWN_COMMAND);
SERIAL_ECHO(cmdbuffer[bufindr]);
}break;
#endif
case 220: // M220 S- set speed factor override percentage
if(code_seen('S'))
feedmultiply = code_value() ;
feedmultiplychanged=true;
break;
case 221: // M221 S- set extrude factor override percentage
if(code_seen('S'))
extrudemultiply = code_value() ;
break;
#ifdef PIDTEMP
case 301: // M301
if(code_seen('P')) Kp = code_value();
if(code_seen('I')) Ki = code_value()*PID_dT;
if(code_seen('D')) Kd = code_value()/PID_dT;
#ifdef PID_ADD_EXTRUSION_RATE
if(code_seen('C')) Kc = code_value();
#endif
updatePID();
SERIAL_PROTOCOL(MSG_OK);
SERIAL_PROTOCOL(" p:");
SERIAL_PROTOCOL(Kp);
SERIAL_PROTOCOL(" i:");
SERIAL_PROTOCOL(Ki/PID_dT);
SERIAL_PROTOCOL(" d:");
SERIAL_PROTOCOL(Kd*PID_dT);
SERIAL_PROTOCOL(" c:");
SERIAL_PROTOCOL(Kc*PID_dT);
#endif
break;
#endif //PIDTEMP
case 240: // M240 Triggers a camera by emulating a Canon RC-1 : [www.doc-diy.net]
const uint8_t NUM_PULSES=16;
const float PULSE_LENGTH=0.01524;
for(int i=0; i < NUM_PULSES; i++) {
WRITE(PHOTOGRAPH_PIN, HIGH);
_delay_ms(PULSE_LENGTH);
delay(7.33);
#endif
#endif
break;
case 302: // allow cold extrudes
allow_cold_extrudes(true);
break;
case 303: // M303 PID autotune
float temp = 150.0;
if (code_seen('S')) temp=code_value();
PID_autotune(temp);
break;
case 400: // M400 finish all moves
st_synchronize();
break;
case 500: // Store settings in EEPROM
EEPROM_StoreSettings();
break;
case 501: // Read settings from EEPROM
break;
case 502: // Revert to default settings
EEPROM_RetrieveSettings(true);
break;
case 503: // print settings currently in memory
EEPROM_printSettings();
break;
case 999: // Restart after being stopped
Stopped = false;
gcode_LastN = Stopped_gcode_LastN;
break;
break;
else if(code_seen('T'))
tmp_extruder = code_value();
if(tmp_extruder >= EXTRUDERS) {
SERIAL_ECHO_START;
SERIAL_ECHO("T");
SERIAL_ECHO(tmp_extruder);
SERIAL_ECHOLN(MSG_INVALID_EXTRUDER);
else {
active_extruder = tmp_extruder;
SERIAL_ECHO_START;
SERIAL_ECHO(MSG_ACTIVE_EXTRUDER);
SERIAL_PROTOCOLLN((int)active_extruder);
else
SERIAL_ECHO_START;
ClearToSend();
void FlushSerialRequestResend()
//char cmdbuffer[bufindr][100]="Resend:";
MYSERIAL.flush();
SERIAL_PROTOCOLPGM(MSG_RESEND);
SERIAL_PROTOCOLLN(gcode_LastN + 1);
ClearToSend();
void ClearToSend()
#ifdef SDSUPPORT
if(fromsd[bufindr])
return;
#endif //SDSUPPORT
void get_coordinates()
bool seen[4]={false,false,false,false};
destination = (float)code_value() + (axis_relative_modes || relative_mode)*current_position;
seen=true;
else destination = current_position; //Are these else lines really needed?
if(code_seen('F')) {
next_feedrate = code_value();
if(next_feedrate > 0.0) feedrate = next_feedrate;
#ifdef FWRETRACT
if(autoretract_enabled)
if( !(seen[X_AXIS] || seen[Y_AXIS] || seen[Z_AXIS]) && seen[E_AXIS])
float echange=destination[E_AXIS]-current_position[E_AXIS];
if(echange<-MIN_RETRACT) //retract
if(!retracted)
destination[Z_AXIS]+=retract_zlift; //not sure why chaninging current_position negatively does not work.
//if slicer retracted by echange=-1mm and you want to retract 3mm, corrrectede=-2mm additionally
float correctede=-echange-retract_length;
//to generate the additional steps, not the destination is changed, but inversely the current position
current_position[E_AXIS]+=-correctede;
retracted=true;
else
if(echange>MIN_RETRACT) //retract_recover
if(retracted)
//current_position[Z_AXIS]+=-retract_zlift;
//if slicer retracted_recovered by echange=+1mm and you want to retract_recover 3mm, corrrectede=2mm additionally
float correctede=-echange+1*retract_length+retract_recover_length; //total unretract=retract_length+retract_recover_length[surplus]
current_position[E_AXIS]+=correctede; //to generate the additional steps, not the destination is changed, but inversely the current position
retracted=false;
#endif //FWRETRACT
#ifdef SF_ARC_FIX
bool relative_mode_backup = relative_mode;
relative_mode = true;
#endif
get_coordinates();
#ifdef SF_ARC_FIX
relative_mode=relative_mode_backup;
#endif
if(code_seen('I')) {
offset[0] = code_value();
else {
offset[0] = 0.0;
if(code_seen('J')) {
offset[1] = code_value();
else {
offset[1] = 0.0;
void clamp_to_software_endstops(float target[3])
if (min_software_endstops) {
if (target[X_AXIS] < min_pos[X_AXIS]) target[X_AXIS] = min_pos[X_AXIS];
if (target[Y_AXIS] < min_pos[Y_AXIS]) target[Y_AXIS] = min_pos[Y_AXIS];
if (target[Z_AXIS] < min_pos[Z_AXIS]) target[Z_AXIS] = min_pos[Z_AXIS];
if (max_software_endstops) {
if (target[X_AXIS] > max_pos[X_AXIS]) target[X_AXIS] = max_pos[X_AXIS];
if (target[Y_AXIS] > max_pos[Y_AXIS]) target[Y_AXIS] = max_pos[Y_AXIS];
if (target[Z_AXIS] > max_pos[Z_AXIS]) target[Z_AXIS] = max_pos[Z_AXIS];
void prepare_move()
clamp_to_software_endstops(destination);
// Do not use feedmultiply for E or Z only moves
if( (current_position[X_AXIS] == destination [X_AXIS]) && (current_position[Y_AXIS] == destination [Y_AXIS])) {
else {
plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate*feedmultiply/60/100.0, active_extruder);
current_position = destination;
void prepare_arc_move(char isclockwise) {
float r = hypot(offset[X_AXIS], offset[Y_AXIS]); // Compute arc radius for mc_arc
// Trace the arc
mc_arc(current_position, destination, offset, X_AXIS, Y_AXIS, Z_AXIS, feedrate*feedmultiply/60/100.0, r, isclockwise, active_extruder);
// As far as the parser is concerned, the position is now == target. In reality the
// motion control system might still be processing the action and the real tool position
// in any intermediate location.
#ifdef CONTROLLERFAN_PIN
unsigned long lastMotor = 0; //Save the time for when a motor was turned on last
unsigned long lastMotorCheck = 0;
void controllerFan()
if ((millis() - lastMotorCheck) >= 2500) //Not a time critical function, so we only check every 2500ms
lastMotorCheck = millis();
if(!READ(X_ENABLE_PIN) || !READ(Y_ENABLE_PIN) || !READ(Z_ENABLE_PIN)
#if EXTRUDERS > 2
|| !READ(E2_ENABLE_PIN)
#endif
#if EXTRUDER > 1
#endif
|| !READ(E0_ENABLE_PIN)) //If any of the drivers are enabled...
lastMotor = millis(); //... set time to NOW so the fan will turn on
if ((millis() - lastMotor) >= (CONTROLLERFAN_SEC*1000UL) || lastMotor == 0) //If the last time any driver was enabled, is longer since than CONTROLLERSEC...
WRITE(CONTROLLERFAN_PIN, LOW); //... turn the fan off
else
WRITE(CONTROLLERFAN_PIN, HIGH); //... turn the fan on
#endif
void manage_inactivity()
if( (millis() - previous_millis_cmd) > max_inactive_time )
if(max_inactive_time)
kill();
if(stepper_inactive_time) {
if( (millis() - previous_millis_cmd) > stepper_inactive_time )
if(blocks_queued() == false) {
disable_x();
disable_y();
disable_z();
disable_e0();
disable_e1();
disable_e2();
#if( KILL_PIN>-1 )
if( 0 == READ(KILL_PIN) )
kill();
#endif
controllerFan(); //Check if fan should be turned on to cool stepper drivers down
#endif
#ifdef EXTRUDER_RUNOUT_PREVENT
if( (millis() - previous_millis_cmd) > EXTRUDER_RUNOUT_SECONDS*1000 )
if(degHotend(active_extruder)>EXTRUDER_RUNOUT_MINTEMP)
bool oldstatus=READ(E0_ENABLE_PIN);
enable_e0();
float oldepos=current_position[E_AXIS];
float oldedes=destination[E_AXIS];
plan_buffer_line(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS],
current_position[E_AXIS]+EXTRUDER_RUNOUT_EXTRUDE*EXTRUDER_RUNOUT_ESTEPS/axis_steps_per_unit[E_AXIS],
EXTRUDER_RUNOUT_SPEED/60.*EXTRUDER_RUNOUT_ESTEPS/axis_steps_per_unit[E_AXIS], active_extruder);
current_position[E_AXIS]=oldepos;
destination[E_AXIS]=oldedes;
plan_set_e_position(oldepos);
previous_millis_cmd=millis();
st_synchronize();
WRITE(E0_ENABLE_PIN,oldstatus);
#endif
check_axes_activity();
void kill()
cli(); // Stop interrupts
disable_heater();
disable_x();
disable_y();
disable_z();
disable_e0();
disable_e1();
disable_e2();
if(PS_ON_PIN > -1) pinMode(PS_ON_PIN,INPUT);
SERIAL_ERROR_START;
SERIAL_ERRORLNPGM(MSG_ERR_KILLED);
LCD_ALERTMESSAGEPGM(MSG_KILLED);
suicide();
while(1); // Wait for reset
void Stop()
disable_heater();
Stopped = true;
Stopped_gcode_LastN = gcode_LastN; // Save last g_code for restart
SERIAL_ERROR_START;
bool IsStopped() { return Stopped; };
#ifdef FAST_PWM_FAN
void setPwmFrequency(uint8_t pin, int val)
val &= 0x07;
switch(digitalPinToTimer(pin))
#if defined(TCCR0A)
case TIMER0A:
case TIMER0B:
// TCCR0B &= ~(CS00 | CS01 | CS02);
// TCCR0B |= val;
break;
#endif
#if defined(TCCR1A)
case TIMER1A:
case TIMER1B:
// TCCR1B &= ~(CS10 | CS11 | CS12);
// TCCR1B |= val;
break;
#endif
#if defined(TCCR2)
case TIMER2:
case TIMER2:
TCCR2 &= ~(CS10 | CS11 | CS12);
TCCR2 |= val;
break;
#endif
#if defined(TCCR2A)
case TIMER2A:
case TIMER2B:
TCCR2B &= ~(CS20 | CS21 | CS22);
TCCR2B |= val;
break;
#endif
#if defined(TCCR3A)
case TIMER3A:
case TIMER3B:
case TIMER3C:
TCCR3B &= ~(CS30 | CS31 | CS32);
TCCR3B |= val;
break;
#endif
#if defined(TCCR4A)
case TIMER4A:
case TIMER4B:
case TIMER4C:
TCCR4B &= ~(CS40 | CS41 | CS42);
TCCR4B |= val;
break;
#endif
#if defined(TCCR5A)
case TIMER5A:
case TIMER5B:
case TIMER5C:
TCCR5B &= ~(CS50 | CS51 | CS52);
TCCR5B |= val;
break;
#endif
#endif //FAST_PWM_FAN
bool setTargetedHotend(int code){
tmp_extruder = active_extruder;
if(code_seen('T')) {
SERIAL_ECHO_START;
switch(code){
case 104:
SERIAL_ECHO(MSG_M104_INVALID_EXTRUDER);
break;
case 105:
SERIAL_ECHO(MSG_M105_INVALID_EXTRUDER);
break;
case 109:
SERIAL_ECHO(MSG_M109_INVALID_EXTRUDER);
break;
SERIAL_ECHOLN(tmp_extruder);
return true;
return false;
August 03, 2013 12:21PM
can you zip and load the entire code you are using. marlin.h is not where the serial comm is done, it is in marlin_serial.h and marlin_serial.cpp
August 04, 2013 05:18AM
Please find attached my entire code!!
Think you!!
open | download - Marlin_Serial2.zip (524.1 KB)
August 05, 2013 02:41AM
it seems the code i gave you a link too has been changed. here is the one i was testing a few months ago. it has 2 serial comms in hardware. 1 will echo the other. it is best if they both are at same baud rate, in fact that is default. it is great for troubleshooting.
with this version you can be hooked up to usb, and wireless at same time. either can run the printer.
just enable bt in configuration.h
Edited 2 time(s). Last edit at 08/05/2013 02:46AM by jamesdanielv.
open | download - terawattindustries-erikzalm-marlin-mendelmax-sfwantai-8e247a401f5d.zip (318.3 KB)
August 05, 2013 06:57AM
Verygood!!
It works fine!! And I found where the error was!!
I use directly this firmware, it is good!! But I prefer mine, because I did a lot of modifications.
I put the new MarlinSoftware.h and MarlinSoftware.cpp, I changed Marlin.h, Marlin_main.cpp, and add MarlinBTSerial.cpp and MarlinBTSerial.h to my project and it works too!!
Think you a lot jamesdanielv for your help!!
I will put the solution in the other topics ;-)
December 27, 2013 06:03AM
Hi all,
I have a 3D printer with the arduino microcontroller Mega2560 , I would like to create a new serial port on the plate with NewSoftSerial SoftwareSerial or library. I can not use any serial port that the mega provided because the pins are occupied . I have only a few free pins , including 11 and 63. In the arduino mega 2560 only certain pins can be used to create a new serial port with SoftwareSerial and NewSoftSerial libreias .
Are the following : 10, 11, 12 , 13, 14 , 15, (I'm not sure these two ) 50, 51,52,53 , 62, 63, 64 , 65, 66, 67, 68 , 69.
I have a made ​​a little program to create the serial port only when I compile this program [1 ] , no errors and funciana well .
The problem biene when I put this little program [1 ] in the marlin [ 2] ( the marlin is the firmware for 3D printer)
No compile me and always gives me error .
[1 ] Nuevo_serial_funciona programilla SoftwareSerial is a very simple
[2 ] is the MARLIN firmware Mega2560 arduino board for the 3D printer works
both program and upload a photo of the part program ke 've changed and fails.
If anyone knows why it gives errors when compiling grateful if you tell me what is the mistake committed estoi .
If anyone would like more information or any questions you can send an email to aguadoimanol@gmail.com
Thank you very much .
open | download - nuevo_serial_funciona.rar (524 bytes)
open | download - MARLIN.rar (168 KB)
open | download - error.png (10.4 KB)
January 04, 2014 01:23PM
i've tried to get it to compile as well, and i think it is not because the pin is somehow defined elsewhere. I'll try to look at it again tonight. I may suggest to use the NewSoftSerial library, rather than the one included with the marlin build.
April 03, 2014 03:55AM
Hi Chik!!
Can you load the entire code you are done finally? .
Thanks
