Print stretched out, Y axis moving more than twice the measure
Posted by Douglas Ramos
October 10, 2013 10:07PM
Hello guys, put together a Prusa Mendel and my first impressions are stretched, as if they were pulled. Another detail is that the table Y command command to move 50mm it advances twice. What could it be?
Re: Print stretched out, Y axis moving more than twice the measure
October 11, 2013 04:59AM
October 11, 2013 12:41PM
Already checked several times and it seems all right, I'll try to erase all settings and do it again, there's something else it could be?
November 08, 2013 07:43PM
Most of the commercial boards use stepper motor controllers. A lot of them have microstepping control inputs, possibly your microstepping hard wired control inputs to the chips have a PCB fault ? i.e. 1/16 instead of 1/32 on one of your boards ?
November 08, 2013 08:40PM
Yes. Check your micro stepping config. You don't say what controller board you are using. On the RAMPS, there are jumpers beneath each stepper driver. Three need to be installed to have 1/16 micro stepping. If your jumpers are wrong, it could very easily cause your axis movements to be off by a factor of two.
