Redefining G28 November 30, 2013 02:52PM |
Re: Redefining G28 November 30, 2013 02:53PM |
case 28: //G28 Home all Axis one at a time #ifdef ENABLE_AUTO_BED_LEVELING //this is not enabled plan_bed_level_matrix.set_to_identity(); //Reset the plane ("erase" all leveling data) #endif //ENABLE_AUTO_BED_LEVELING saved_feedrate = feedrate; saved_feedmultiply = feedmultiply; feedmultiply = 100; previous_millis_cmd = millis(); enable_endstops(true); for(int8_t i=0; i < NUM_AXIS; i++) { destination = current_position; } feedrate = 0.0; #ifdef DELTA // this is not a delta-printer // A delta can only safely home all axis at the same time // all axis have to home at the same time // Move all carriages up together until the first endstop is hit. current_position[X_AXIS] = 0; current_position[Y_AXIS] = 0; current_position[Z_AXIS] = 0; plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); destination[X_AXIS] = 3 * Z_MAX_LENGTH; destination[Y_AXIS] = 3 * Z_MAX_LENGTH; destination[Z_AXIS] = 3 * Z_MAX_LENGTH; feedrate = 1.732 * homing_feedrate[X_AXIS]; plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate/60, active_extruder); st_synchronize(); endstops_hit_on_purpose(); current_position[X_AXIS] = destination[X_AXIS]; current_position[Y_AXIS] = destination[Y_AXIS]; current_position[Z_AXIS] = destination[Z_AXIS]; // take care of back off and rehome now we are all at the top HOMEAXIS(X); HOMEAXIS(Y); HOMEAXIS(Z); calculate_delta(current_position); plan_set_position(delta[X_AXIS], delta[Y_AXIS], delta[Z_AXIS], current_position[E_AXIS]); #else // NOT DELTA home_all_axis = !((code_seen(axis_codes[0])) || (code_seen(axis_codes[1])) || (code_seen(axis_codes[2]))); #if Z_HOME_DIR > 0 // If homing away from BED do Z first -> it does NOT home away from bed if((home_all_axis) || (code_seen(axis_codes[Z_AXIS]))) { HOMEAXIS(Z); } #endif #ifdef QUICK_HOME // QUICK_HOME is false thus not using this feature if((home_all_axis)||( code_seen(axis_codes[X_AXIS]) && code_seen(axis_codes[Y_AXIS])) ) //first diagonal move { current_position[X_AXIS] = 0;current_position[Y_AXIS] = 0; #ifndef DUAL_X_CARRIAGE int x_axis_home_dir = home_dir(X_AXIS); #else int x_axis_home_dir = x_home_dir(active_extruder); extruder_duplication_enabled = false; #endif plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); destination[X_AXIS] = 1.5 * max_length(X_AXIS) * x_axis_home_dir;destination[Y_AXIS] = 1.5 * max_length(Y_AXIS) * home_dir(Y_AXIS); feedrate = homing_feedrate[X_AXIS]; if(homing_feedrate[Y_AXIS]<feedrate) feedrate =homing_feedrate[Y_AXIS]; plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate/60, active_extruder); st_synchronize(); axis_is_at_home(X_AXIS); axis_is_at_home(Y_AXIS); plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); destination[X_AXIS] = current_position[X_AXIS]; destination[Y_AXIS] = current_position[Y_AXIS]; plan_buffer_line(destination[X_AXIS], destination[Y_AXIS], destination[Z_AXIS], destination[E_AXIS], feedrate/60, active_extruder); feedrate = 0.0; st_synchronize(); endstops_hit_on_purpose(); current_position[X_AXIS] = destination[X_AXIS]; current_position[Y_AXIS] = destination[Y_AXIS]; current_position[Z_AXIS] = destination[Z_AXIS]; } #endif if((home_all_axis) || (code_seen(axis_codes[X_AXIS]))) { #ifdef DUAL_X_CARRIAGE // not using dual x carriage int tmp_extruder = active_extruder; extruder_duplication_enabled = false; active_extruder = !active_extruder; HOMEAXIS(X); inactive_extruder_x_pos = current_position[X_AXIS]; active_extruder = tmp_extruder; HOMEAXIS(X); // reset state used by the different modes memcpy(raised_parked_position, current_position, sizeof(raised_parked_position)); delayed_move_time = 0; active_extruder_parked = true; #else HOMEAXIS(X); #endif } if((home_all_axis) || (code_seen(axis_codes[Y_AXIS]))) { HOMEAXIS(Y); } if((home_all_axis)) { // I have added the following if-statements with the content tabbed current_position[X_AXIS]=MANUAL_X_HOME_POS; current_position[Y_AXIS]=MANUAL_Y_HOME_POS; feedrate=6000; destination[0]=X_MIN_POS; destination[1]=Y_MAX_LENGTH / 2; destination[2]=current_position[Z_AXIS]; prepare_move(); //ClearToSend(); } #if Z_HOME_DIR < 0 // If homing towards BED do Z last if((home_all_axis) || (code_seen(axis_codes[Z_AXIS]))) { HOMEAXIS(Z); } if((home_all_axis)) { current_position[Z_AXIS]=MANUAL_Z_HOME_POS; feedrate=6000; destination[0]=current_position[X_AXIS]; destination[1]=current_position[Y_AXIS]; destination[2]= Z_MIN_POS + 10; prepare_move(); //ClearToSend(); } if((home_all_axis)) { feedrate=6000; destination[0]=current_position[X_AXIS]; destination[1]=Y_MIN_POS; destination[2]=current_position[Z_AXIS]; prepare_move(); //ClearToSend(); } #endif if(code_seen(axis_codes[X_AXIS])) { if(code_value_long() != 0) { current_position[X_AXIS]=code_value()+add_homeing[0]; } } if(code_seen(axis_codes[Y_AXIS])) { if(code_value_long() != 0) { current_position[Y_AXIS]=code_value()+add_homeing[1]; } } if(code_seen(axis_codes[Z_AXIS])) { if(code_value_long() != 0) { current_position[Z_AXIS]=code_value()+add_homeing[2]; } } #ifdef ENABLE_AUTO_BED_LEVELING current_position[Z_AXIS] -= Z_PROBE_OFFSET_FROM_EXTRUDER; //Add Z_Probe offset (the distance is negative) #endif plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]); #endif // else DELTA #ifdef ENDSTOPS_ONLY_FOR_HOMING enable_endstops(false); #endif feedrate = saved_feedrate; feedmultiply = saved_feedmultiply; previous_millis_cmd = millis(); endstops_hit_on_purpose(); break;
Re: Redefining G28 November 30, 2013 02:54PM |
MANUAL_X_HOME_POS -60 MANUAL_Y_HOME_POS -10 <- MANUAL_Z_HOME_POS -3.3 <- X_MAX_POS 205 <- X_MIN_POS 0 <- Y_MAX_POS 205 Y_MIN_POS 0 Z_MAX_POS 370 Z_MIN_POS 0
Re: Redefining G28 December 01, 2013 05:31AM |
- Home the x-axis
- Home the y-axis
- Go to position: ( 0 , Y_MAX_LENGTH / 2 , current_position[Z_AXIS] )
- Home the z-axis
- Go to position: ( 0 , 0 , 10 )
G28 XY G1 X0 Y100 G28 Z G1 X Y Z10
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Redefining G28 December 01, 2013 01:59PM |
Re: Redefining G28 January 13, 2014 05:32PM |
