Re: Project: Teacup Firmware October 27, 2011 10:33PM |
#define X_INVERT_ENABLE #define Y_INVERT_ENABLE #define Z_INVERT_ENABLE
#define E_INVERT_ENABLE
Re: Project: Teacup Firmware October 28, 2011 07:14AM |
Teacup doesn't seem to look at the endstop signal
Anyway, in home.c, there are two errors in lines 82 and 88
Either the config.h for RAMPS 1.2 need to be change so only the *_MIN_PIN parameters are defined and/or lines 27-31 of the home.c code need to be rewritten so that the z is consistent with the other axes
My reason for doing this is to see if Teacup can execute G-code faster than Sprinter since it uses integer math.
i'm still bother by the fact that microcontroller/firmware can't seem to keep up with short segments. So far, I haven't seen an improvement when run without acceleration.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware October 28, 2011 07:32AM |
I encountered the same problem ...
Re: Project: Teacup Firmware October 29, 2011 03:33PM |
Traumflug
Without acceleration, stepper motors simply can't get up to their maximum speed for mechanical reasons, so if your motors move without acceleration you're far behind what's possible. More likely, communications over the serial line is the bottleneck here. Raising MOVEBUFFER_SIZE in config.h helps a lot, you can raise it up to the point where 90% RAM are used. "make" in the command line will report RAM usage.
Re: Project: Teacup Firmware October 30, 2011 07:31AM |
Re: Project: Teacup Firmware October 30, 2011 08:00AM |
Re: Project: Teacup Firmware October 30, 2011 09:54AM |
Re: Project: Teacup Firmware October 30, 2011 08:50PM |
Re: Project: Teacup Firmware October 31, 2011 03:36AM |
marlin and sjfw have this capability, both based off grbl as far as I know
Re: Project: Teacup Firmware October 31, 2011 08:53AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Project: Teacup Firmware November 01, 2011 04:41AM |
Re: Project: Teacup Firmware November 01, 2011 04:55AM |
Re: Project: Teacup Firmware November 01, 2011 06:21AM |
What else can you do without straying from the correct trajectory?
Re: Project: Teacup Firmware November 01, 2011 11:05PM |
Re: Project: Teacup Firmware November 02, 2011 07:22AM |
Re: Project: Teacup Firmware November 08, 2011 05:54PM |
Re: Project: Teacup Firmware November 09, 2011 04:25AM |
everything works great but shuts off after 30 seconds if I don't move any axis
Re: Project: Teacup Firmware November 09, 2011 08:51AM |
Re: Project: Teacup Firmware November 10, 2011 05:57AM |
With either or both heater turned on, it still turns off after 30 seconds.
Re: Project: Teacup Firmware November 10, 2011 06:06AM |
Re: Project: Teacup Firmware November 10, 2011 06:46AM |
Re: Project: Teacup Firmware November 11, 2011 03:40AM |
I think eeconfig could be generalised to a runtime configuration system
Re: Project: Teacup Firmware November 11, 2011 04:36AM |
Re: Project: Teacup Firmware November 21, 2011 04:16AM |
See: [github.com]| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware December 11, 2011 01:33PM |
Re: Project: Teacup Firmware December 12, 2011 04:19AM |
Re: Project: Teacup Firmware December 12, 2011 03:46PM |
Re: Project: Teacup Firmware December 12, 2011 09:20PM |
#define STEPS_PER_M_X (5023*MICROSTEPPING_X)with
#define STEPS_PER_M_X 80368i.e., calculate the value manually and insert a single number only. It's a bit disappointing the preprocessor can't so this for us.
Re: Project: Teacup Firmware December 13, 2011 09:09AM |
Re: Project: Teacup Firmware December 13, 2011 01:34PM |
