Re: Project: Teacup Firmware March 03, 2012 11:08AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware March 03, 2012 11:21AM |
Re: Project: Teacup Firmware March 06, 2012 08:50AM |
Re: Project: Teacup Firmware March 18, 2012 05:43AM |
Re: Project: Teacup Firmware March 19, 2012 08:45AM |
Re: Project: Teacup Firmware March 25, 2012 02:29PM |
Re: Project: Teacup Firmware March 26, 2012 11:17AM |
Re: Project: Teacup Firmware March 27, 2012 07:24AM |
MEMORY_BARRIER();
SREG = sreg_save;
#include "memory_barrier.h"after #include <avr/interrupt.h> in intercom.c should fix tis properly.
Re: Project: Teacup Firmware March 27, 2012 08:57AM |
Re: Project: Teacup Firmware March 27, 2012 10:58AM |
Re: Project: Teacup Firmware March 28, 2012 07:01AM |
Re: Project: Teacup Firmware March 28, 2012 11:15AM |
Re: Project: Teacup Firmware March 28, 2012 04:29PM |
Re: Project: Teacup Firmware March 28, 2012 05:51PM |
Re: Project: Teacup Firmware March 29, 2012 04:13AM |
But Traumflug, do you see a possibility to implement some kind of hysteresis in the ON/OFF control for the bed?
Re: Project: Teacup Firmware March 29, 2012 10:50AM |
Project: Teacup Firmware for generation 4 July 11, 2012 01:55AM |
Re: Project: Teacup Firmware July 13, 2012 05:47AM |
Re: Project: Teacup Firmware July 15, 2012 07:51AM |
Re: Project: Teacup Firmware July 21, 2012 06:09AM |
The extreme values for the OCR0A Register represents special cases when generating a PWM waveform output in the fast PWM mode. If the OCR0A is set equal to BOTTOM, the output will be a narrow spike for each MAX+1 timer clock cycle.
Re: Project: Teacup Firmware July 23, 2012 05:59AM |
The workaround seems to be turning off PWM completely instead of setting the PWM to zero. Is this a known issue with the firmware, or maybe considered a "feature"?
Re: Project: Teacup Firmware August 09, 2012 03:13AM |
Re: Project: Teacup Firmware August 09, 2012 10:17AM |
For example if i have extruder i catch all his gcodes and execute them.
And i see TODO note that all steppers should be in loop. Question is - does anybody will or have already rewritten this code to make a loop from it?
typedef struct {
// bresenham counters
int32_t x_counter;
int32_t y_counter;
int32_t z_counter;
int32_t e_counter;
totypedef struct {
union {
struct {
int32_t x_counter;
int32_t y_counter;
int32_t z_counter;
int32_t e_counter;
int32_t bresenham[NUM_AXIS];
Following such a path allows to change only parts of the code, making commits much more readable and not breaking everything if some pieces of the loop conversion are (intentionally or not) missed.| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware August 09, 2012 10:34AM |
Re: Project: Teacup Firmware August 10, 2012 06:47AM |
if i send gcode in same time (almost, few cpu ticks later) to all modules, and every module do their job correctly
Re: Project: Teacup Firmware August 10, 2012 06:49AM |
Re: Project: Teacup Firmware August 10, 2012 07:11AM |
Re: Project: Teacup Firmware August 10, 2012 09:18AM |
Re: Project: Teacup Firmware August 10, 2012 09:51PM |
Re: Project: Teacup Firmware August 11, 2012 03:23AM |
