Re: Project: Teacup Firmware February 27, 2013 05:18PM |
Re: Project: Teacup Firmware February 28, 2013 06:39AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware February 28, 2013 12:06PM |
Re: Project: Teacup Firmware February 28, 2013 02:14PM |
Re: Project: Teacup Firmware February 28, 2013 02:30PM |
Re: Project: Teacup Firmware March 03, 2013 07:01AM |
Re: Project: Teacup Firmware March 24, 2013 11:49AM |
Re: Project: Teacup Firmware March 26, 2013 04:54AM |
Re: Project: Teacup Firmware March 27, 2013 11:02AM |
Re: Project: Teacup Firmware March 28, 2013 03:01PM |
BTW., I think most other RepRap firmwares set an divider of 8 for the step interrupt, so timing is not entirely as accurate as with Teacup, but the 32 bit extension can be avoided. They then get maximum delays of (1 / F_CPU) * 65535 * 8 = 0.026 s = 26 ms. Translates to a minimum feedrate of 38 steps/second or 288 mm/min on a half-stepping, belt driven axis. With Teacup, I've done successful movements at F0.1 (for EDM) already.
Re: Project: Teacup Firmware March 31, 2013 06:56PM |
Re: Project: Teacup Firmware April 01, 2013 01:31PM |
Re: Project: Teacup Firmware April 01, 2013 03:54PM |
Re: Project: Teacup Firmware April 01, 2013 09:37PM |
git remote set-url origin [github.com] # 'origin' git fetch origin
git branch accel_clock origin/accel_clock
Re: Project: Teacup Firmware April 01, 2013 11:03PM |
Re: Project: Teacup Firmware April 02, 2013 02:22AM |
Re: Project: Teacup Firmware April 02, 2013 03:00AM |
Admin Registered: 11 years ago Posts: 1,063 |
Re: Project: Teacup Firmware April 02, 2013 07:00AM |
Will that be the same for an arduino mega2560 with 16Mhz?
whats the new pulse width if it had changed?
Re: Project: Teacup Firmware April 02, 2013 08:26AM |
Re: Project: Teacup Firmware April 02, 2013 08:27AM |
Re: Project: Teacup Firmware April 02, 2013 03:03PM |
Re: Project: Teacup Firmware April 03, 2013 02:35AM |
karabas
What about comport connection speed bottleneck? For currect firmwares it's not higher 250000baud. Thar's too slow for "high density" gcode and some of us are forced to print from sdcards for better prints.
DaveX
I think that bottleneck is in the electronics rather than the firmware. Doesn't hardware with built-in USB chips, like the atmega32u4 on the Teensy 2.0 (and perhaps the at90usb1286 on the printrboard) ignore the baud rate and communicate at up to the full speed USB of 12Mbit/sec? With pronterface or pronsole, I can connect at "9600" to my Teensy2.0 and communicate with visually undetectable latency.
Re: Project: Teacup Firmware April 03, 2013 12:05PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Project: Teacup Firmware April 03, 2013 04:47PM |
2,770 bytes/sec Parsed by Teacup/Gen7 on a 16MHz Teensy 2.0 72,674 bytes/sec Parsed by a simple Arduino sketch that read and discarded single bytes out of the USB buffer 500,000 bytes/sec Parsed by a simple Arduino sketch that flushes the USB buffer after receiving it.
23,809 bytes/sec Parsed by Teacup/Gen7 on a 16MHz Teensy 2.0 76,923 bytes/sec Parsed by a simple Arduino sketch that read and discarded single bytes out of the USB buffer 500,000 bytes/sec Parsed by a simple Arduino sketch that flushes the USB buffer after receiving it.
21,739 bytes/sec Parsed by Teacup/Gen7 on a 16MHz Teensy 2.0 76,923 bytes/sec Parsed by a simple Arduino sketch that read and discarded single bytes out of the USB buffer 500,000 bytes/sec Parsed by a simple Arduino sketch that flushes the USB buffer after receiving it.
Re: Project: Teacup Firmware April 05, 2013 03:19AM |
Re: Project: Teacup Firmware April 05, 2013 07:32AM |
Is it possible to use teacap at all?
Re: Project: Teacup Firmware April 10, 2013 11:18PM |
Re: Project: Teacup Firmware April 25, 2013 04:52AM |
Re: Project: Teacup Firmware April 26, 2013 07:43AM |
Re: Project: Teacup Firmware April 26, 2013 07:58AM |
