Re: Project: Teacup Firmware April 26, 2015 04:44PM |
Re: Project: Teacup Firmware April 26, 2015 07:15PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware May 14, 2015 01:14PM |
Re: Project: Teacup Firmware May 14, 2015 03:45PM |
theothermike
dda.c:226: error: 'DDA' has no member named 'delta_um'
dda.c:228: error: 'DDA' has no member named 'delta_um'
Re: Project: Teacup Firmware May 14, 2015 05:37PM |
Re: Project: Teacup Firmware May 17, 2015 07:36PM |
Re: Project: Teacup Firmware May 17, 2015 07:56PM |
Re: Project: Teacup Firmware May 17, 2015 08:09PM |
Re: Project: Teacup Firmware May 18, 2015 06:59AM |
ghost2501
I saw another thread that says teacup does not support g2 adn g3 commands?
ghost2501
if so would i just use find adn replace all g2 with g1 etc. would that work for curves and arcs?
Re: Project: Teacup Firmware May 23, 2015 01:30AM |
Traumflug
For just X and Y you currently have to define Z and E as well ... and ignore the latter two. Patches to change this are welcome, of course, some 50% of this work has been done already.
Power is like a heater without temperature sensor. Using M106 to regulate between S0 and S255. Simply remove the other heater and both temp sensors from the template.
The same could be used for the on/off pin, but I guess you'd prefer something which doesn't require explicite G-code. The X or Y enable pin might fit this bill well.
Wait, perhaps it's even better to define a DC extruder to operate this laser. This has both, PWM and on/off as well. Operated with M103, IIRC.
You also might prefer to use Teacup Configtool, which is currently on the experimental branch only. Only few known bugs left and we're happy to hear of the other ones. Much easier to use thean Arduino IDE. Start with ./configtool.py, load a board, load a printer (the closest to your actual one), then build & upload. Help is in the tooltips, simply hover over the individual fields.
Re: Project: Teacup Firmware May 23, 2015 07:14AM |
ghost2501
So when you say a DC extruder you mean its for a non stepper motor extruder? does the command go something like m103 s127 do adjust the pwm?
ghost2501
Basically I need a nice neat command to fire the laser on one pin and set the power (pwm) on another pin from one thing like m103 s127 would turn pin 1 high making the s127 part would make pin 2 do 50% duty cycle. Is that possible because I have no use for a pwm on off pin as I am stricktly laser cutting and need the laser on 100% of the time durring cuts but I still need to set its power.
ghost2501
This is where I go back in a circle and havent yet seen a good solution yet
ghost2501
This is also where I get nervous about all the talk of acceleration and lookahead
ghost2501
Smoothieware talks about having to accelerate around curves
ghost2501
Or am I just confused and acceleration etc. themsleves [...]
Re: Project: Teacup Firmware May 23, 2015 09:43AM |
Re: Project: Teacup Firmware May 23, 2015 11:29AM |
Re: Project: Teacup Firmware May 25, 2015 12:10PM |
Re: Project: Teacup Firmware May 25, 2015 12:25PM |
Re: Project: Teacup Firmware May 25, 2015 12:35PM |
Re: Project: Teacup Firmware May 25, 2015 12:48PM |
Re: Project: Teacup Firmware May 25, 2015 01:00PM |
Re: Project: Teacup Firmware May 25, 2015 01:04PM |
Re: Project: Teacup Firmware May 25, 2015 01:08PM |
Re: Project: Teacup Firmware May 25, 2015 01:11PM |
Teacup Configtool out to the public! June 01, 2015 08:39AM |
Re: Project: Teacup Firmware June 02, 2015 04:59AM |
Re: Project: Teacup Firmware June 02, 2015 07:05AM |
Re: Project: Teacup Firmware June 02, 2015 07:38AM |
Re: Project: Teacup Firmware June 02, 2015 07:44AM |
Re: Project: Teacup Firmware June 02, 2015 07:53AM |
Re: Project: Teacup Firmware June 02, 2015 08:16AM |
Re: Project: Teacup Firmware June 02, 2015 08:53AM |
leadinglights
Nor would I expect you to. I had hoped though that you could give some starting points such as if there is or is not already code for I2C or SPI in Teacup.
It is not my intention to port to a PIC, only to use a PIC controller to do the actual tool change - that is well within my abilities. Deciding whether to use Teacup or something else is my present quest.
Mike
Re: Project: Teacup Firmware June 02, 2015 09:10AM |
