Re: Project: Teacup Firmware June 02, 2015 09:31AM |
Re: Project: Teacup Firmware June 02, 2015 09:41AM |
Re: Project: Teacup Firmware June 02, 2015 10:05AM |
dc42
leadinglights
Nor would I expect you to. I had hoped though that you could give some starting points such as if there is or is not already code for I2C or SPI in Teacup.
It is not my intention to port to a PIC, only to use a PIC controller to do the actual tool change - that is well within my abilities. Deciding whether to use Teacup or something else is my present quest.
Mike
You might want to look at how RepRapFirmware on Duet electronics handles tool changes. Whenever a tool is released, a macro file for that tool is run. Whenever a tool is selected, another macro file is run; then the tool heaters are commanded to operating temperature; finally a 3rd macro file is run. The macro files contain ordinary gcodes, so you can do what you like in them. The standard firmware configuration supports up to 5 extruders and 6 heaters.
Re: Project: Teacup Firmware June 02, 2015 10:32AM |
AndrewBCN
dc42
leadinglights
Mike
@dc42 - offtopic and sort of thread hijacking here. Could you please discuss RepRapFirmware programming in a separate thread or PM Mike about it?
Re: Project: Teacup Firmware June 02, 2015 12:53PM |
AndrewBCN
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware June 02, 2015 12:57PM |
leadinglights
I have been asking for any thoughts or assistance in how to control a whole bunch of extruders and a extruder swapper.
leadinglights
Does Teacup have a way of sending out and receiving commands from a RAMPS board through SPI, I2C or serial interfaces?
Re: Project: Teacup Firmware June 02, 2015 03:02PM |
Traumflug
leadinglights
You didn't. This was your question:
leadinglights
Re: Project: Teacup Firmware June 02, 2015 03:30PM |
leadinglights
Although I will be ordering a a Duet/Duex combination this is as a fall back position, it still has one stepper motor too few for my requirements (5 extruders, 1 extruder swap motor and a lift solenoid plus 5 heaters)
Re: Project: Teacup Firmware June 09, 2015 03:28PM |
Re: Project: Teacup Firmware June 10, 2015 05:22AM |
Re: Project: Teacup Firmware June 10, 2015 11:32PM |
Traumflug
a) put this issue into the issue tracker and
Traumflug
b) start checking late in dda_create() to see wether these homing movements cause E steps (dda->steps[E]).
Re: Project: Teacup Firmware June 15, 2015 05:43PM |
leadinglights
Mike
Re: Project: Teacup Firmware June 15, 2015 06:05PM |
thetazzbot
Teacup: Since it is not Arduino specific, you would have to implement an I2C or SPI stack.
Re: Project: Teacup Firmware June 16, 2015 02:40AM |
Re: Project: Teacup Firmware June 16, 2015 02:50AM |
thetazzbot
How about the ultralcd support?
Re: Project: Teacup Firmware June 16, 2015 10:59AM |
Traumflug
thetazzbot
The SPI part was done over the last few days, as part of SD card reading. It's in the sdcard3 branch.
Re: Project: Teacup Firmware June 16, 2015 11:00AM |
Re: Project: Teacup Firmware June 19, 2015 01:10PM |
/***************************************************************************\ * * * 1. CPU * * * \***************************************************************************/ /** \def CPU_TYPE CPU types a user should be able to choose from in configtool. All commented out. */ //#define CPU_TYPE atmega328 /** \def CPU CPU actually present on the board. */ #define CPU atmega328 /** \def F_CPU_OPT CPU clock frequencies a user should be able to choose from in configtool. All commented out. */ //#define F_CPU_OPT 16000000UL /** \def F_CPU Actual CPU clock rate. #ifndef required for Arduino compatibility. */ #ifndef F_CPU #define F_CPU 16000000UL #endif /** \def MOTHERBOARD This is the motherboard, as opposed to the extruder. See extruder/ directory for GEN3 extruder firmware. */ #define MOTHERBOARD /***************************************************************************\ * * * 2. PINOUTS * * * \***************************************************************************/ #define X_STEP_PIN DIO2 #define X_DIR_PIN DIO5 #define X_MIN_PIN DIO9 //#define X_MAX_PIN DIO21 #define X_ENABLE_PIN DIO8 //#define X_INVERT_DIR #define X_INVERT_MIN #define X_INVERT_MAX #define X_INVERT_ENABLE #define Y_STEP_PIN DIO3 #define Y_DIR_PIN DIO6 #define Y_MIN_PIN DIO10 //#define Y_MAX_PIN DIO26 #define Y_ENABLE_PIN DIO8 //#define Y_INVERT_DIR #define Y_INVERT_MIN #define Y_INVERT_MAX #define Y_INVERT_ENABLE #define Z_STEP_PIN DIO4 #define Z_DIR_PIN DIO7 #define Z_MIN_PIN DIO11 //#define Z_MAX_PIN DIO31 #define Z_ENABLE_PIN DIO8 //#define Z_INVERT_DIR #define Z_INVERT_MIN #define Z_INVERT_MAX #define Z_INVERT_ENABLE #define E_STEP_PIN DIO12 #define E_DIR_PIN DIO13 #define E_ENABLE_PIN DIO8 //#define E_INVERT_DIR //#define E_INVERT_ENABLE //#define PS_ON_PIN DIO14 //#define PS_MOSFET_PIN xxxx //#define STEPPER_ENABLE_PIN DIO25 //#define STEPPER_INVERT_ENABLE /** \def DEBUG_LED_PIN Enable flashing of a LED during motor stepping. Disabled by default. Uncommenting this makes the binary a few bytes larger and adds a few cycles to the step timing interrrupt in timer.c. Also used for precision profiling (profiling works even without actually having such a LED in hardware), see [reprap.org] */ //#define DEBUG_LED_PIN DIO21 /***************************************************************************\ * * * 3. TEMPERATURE SENSORS * * * \***************************************************************************/ #ifndef DEFINE_TEMP_SENSOR #define DEFINE_TEMP_SENSOR(...) #endif /** \def TEMP_MAX6675 TEMP_THERMISTOR TEMP_AD595 TEMP_PT100 TEMP_INTERCOM Which temperature sensor types are you using? Leave all used ones uncommented, comment out all others to save binary size and enhance performance. */ //#define TEMP_MAX6675 #define TEMP_THERMISTOR //#define TEMP_AD595 //#define TEMP_PT100 //#define TEMP_INTERCOM /** \def TEMP_SENSOR_PIN Temperature sensor pins a user should be able to choose from in configtool. All commented out. */ //#define TEMP_SENSOR_PIN AIO3 /** \def DEFINE_TEMP_SENSOR Define your temperature sensors here. One line for each sensor, only limited by the number of available ATmega pins. Name must match the name of the corresponding heater. If a heater "extruder" exists, a temperature sensor of that name has to exist as well. Same for heater "bed". There can be one sensor without corresponding heater, name it "noheater". Types are same as TEMP_ list above - TT_MAX6675, TT_THERMISTOR, TT_AD595, TT_PT100, TT_INTERCOM. See list in temp.c. The "additional" field is used for TT_THERMISTOR only. It defines the name of the table(s) in thermistortable.h to use. This name is arbitrary, often used names include THERMISTOR_EXTRUDER and THERMISTOR_BED. Also, several sensors can share the same table, which saves binary size. For a GEN3 set temp_type to TT_INTERCOM and temp_pin to AIO0. The pin won't be used in this case. */ //DEFINE_TEMP_SENSORS_START // name type pin additional DEFINE_TEMP_SENSOR(Hotend, TT_THERMISTOR, AIO3, THERMISTOR_HOTEND) // Beta algorithm r0 beta r2 vadc // Steinhart-Hart rp t0 r0 t1 r1 t2 r2 //TEMP_TABLE HOTEND (100000, 4066, 4700, 5.0) //DEFINE_TEMP_SENSORS_END /***************************************************************************\ * * * 4. HEATERS * * * \***************************************************************************/ #ifndef DEFINE_HEATER #define DEFINE_HEATER(...) #endif /** \def HEATER_PIN Heater pins a user should be able to choose from in configtool. All commented out. */ /** \def DEFINE_HEATER Define your heaters and devices here. To attach a heater to a temp sensor above, simply use exactly the same name - copy+paste is your friend. Some common names are 'extruder', 'bed', 'fan', 'motor', ... names with special meaning can be found in gcode_process.c. Currently, these are: HEATER_extruder (M104) HEATER_bed (M140) HEATER_fan (M106) Devices don't neccessarily have a temperature sensor, e.g. fans or milling spindles. Operate such devices by setting their power (M106), instead of setting their temperature (M104). Also note, the index of a heater (M106 P#) can differ from the index of its attached temperature sensor (M104 P#) in case sensor-less devices are defined or the order of the definitions differs. The first defined device has the index 0 (zero). Set 'pwm' to ... 1 for using PWM on a PWM-able pin and on/off on other pins. 0 for using on/off on a PWM-able pin, too. Using PWM usually gives smoother temperature control but can conflict with slow switches, like solid state relays. PWM frequency can be influenced globally with FAST_PWM, see below. */ //DEFINE_HEATERS_START // name port pwm DEFINE_HEATER(Hotend, AIO2, 1) #define HEATER_HOTEND HEATER_Hotend //DEFINE_HEATERS_END /***************************************************************************\ * * * 5. COMMUNICATION OPTIONS * * * \***************************************************************************/ /** \def BAUD Baud rate for the serial RS232 protocol connection to the host. Usually 115200, other common values are 19200, 38400 or 57600. Ignored when USB_SERIAL is defined. */ #define BAUD 115200 /** \def XONXOFF Xon/Xoff flow control. Redundant when using RepRap Host for sending G-code, but mandatory when sending G-code files with a plain terminal emulator, like GtkTerm (Linux), CoolTerm (Mac) or HyperTerminal (Windows). */ //#define XONXOFF /** \def USB_SERIAL Define this for using USB instead of the serial RS232 protocol. Works on USB-equipped ATmegas, like the ATmega32U4, only. */ //#define USB_SERIAL
Re: Project: Teacup Firmware June 19, 2015 01:52PM |
Traumflug
thetazzbot
I see no reason why this should happen. Plenty of [censored] yelling wishlists, zero people actually writing such code. For me, there are more interesting things to hack, e.g. jerk-less look-ahead, which is something I'd have actual use for.
Re: Project: Teacup Firmware June 19, 2015 03:25PM |
thetazzbot
I'm quite a nice guy And a developer
thetazzbot
if you don't have any objections I wouldn't mind forking Teacup to see if I can add in the lcd support. I would love to see Teacup with LCD and SD card and that's just about all I'd add to it Because then it will be perfect (for my selfish needs) .
Re: Project: Teacup Firmware June 19, 2015 03:44PM |
madmike8
I'm using AIO2 (UNO) / Resume (CNC Shield) for the Hotend Seven Switch Connection
madmike8
It would be nice is all the CPU's were listed.
//#define CPU_TYPE atmega168 //#define CPU_TYPE atmega168p //#define CPU_TYPE atmega328 //#define CPU_TYPE atmega328p
madmike8
Does the CPU part look right?
Re: Project: Teacup Firmware June 19, 2015 03:55PM |
Re: Project: Teacup Firmware June 21, 2015 11:38AM |
Re: Project: Teacup Firmware June 22, 2015 10:09AM |
Traumflug
Thanks. I think it's about time to add one or two of these Nano/Uno based setups to the distribution, so I looked into it. One thing I found is, you name the extruder "hotend", which requires adding a P0 to each M104 and gives a slightly different answer text on M105. Renaming this to "extruder" would fix this. "extruder", "bed" and "fan" are names with a special meaning, see the tooltip when hovering over the"add sensor""Add" button on the heater tab.
Re: Project: Teacup Firmware July 01, 2015 11:17AM |
Re: Project: Teacup Firmware July 01, 2015 11:22AM |
Please answer these questions before hitting "send": What did you try to do? What did you expect to happen? What happened instead?
Re: Project: Teacup Firmware July 06, 2015 02:18PM |
Re: Project: Teacup Firmware July 10, 2015 07:05AM |
Admin Registered: 11 years ago Posts: 1,063 |
thetazzbot
Traumflug
thetazzbot
For the record, I'm not an [censored], actually I'm quite a nice guy And a developer, so if you don't have any objections I wouldn't mind forking Teacup to see if I can add in the lcd support. I would love to see Teacup with LCD and SD card and that's just about all I'd add to it Because then it will be perfect (for my selfish needs) .
Re: Project: Teacup Firmware July 11, 2015 05:23AM |
thejollygrimreaper
have you done anything with this?
Re: Project: Teacup Firmware July 14, 2015 05:24PM |
Admin Registered: 13 years ago Posts: 730 |
Traumflug
thejollygrimreaper
thetazzbot
Traumflug
thetazzbot
have you done anything with this? i'm curious as i'm also looking at the possibility of lcd support now that the sdcard stuff is working
Maybe he did, but certainly nothing publicly visible. That much to "I'm a nice guy" and "I'm not an [censored]".
