Re: Project: Teacup Firmware August 16, 2016 06:46AM |
Re: Project: Teacup Firmware August 16, 2016 06:58AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware August 18, 2016 05:49AM |
Re: Project: Teacup Firmware August 18, 2016 06:12AM |
HugoYu33
I attach the message of building FW and uploading FW.
I guess that these two messages are what you want to know?
Re: Project: Teacup Firmware August 18, 2016 06:44AM |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: Project: Teacup Firmware September 05, 2016 02:42AM |
Re: Project: Teacup Firmware September 05, 2016 05:28AM |
HugoYu33
I modify MOVEBUFFER_SIZE from 96 to 64, the RAM size used is changed to 89.78% from 131.58%. Then issue is gone.
HugoYu33
When I power on the printer and connect to Pronterface, stepper motor(X,Y,E axis, not include Z axis) will keep a force, even no print action is applied, just idle.
HugoYu33
After a while (about 10 Mins) temperature of motor will increase quickly and temperature of A4988 heat sink also become very hot.
Re: Project: Teacup Firmware September 07, 2016 10:50PM |
Re: Project: Teacup Firmware September 08, 2016 04:17AM |
HugoYu33
So I have a question that why printer can't work normally when using Repetier_Host to print a object
Re: Project: Teacup Firmware September 08, 2016 04:26AM |
Re: Project: Teacup Firmware September 08, 2016 05:06AM |
Re: Project: Teacup Firmware October 25, 2016 01:37PM |
Traumflug
One additional thing: these number given by the compiler don't take stack memory into account, so one can't even use 100%. The amount of RAM needed for stacks isn't clearly defined, it depends on the program flow. Sticking below 90% RAM with that compiler number should be safe.
Re: Project: Teacup Firmware October 25, 2016 01:54PM |
Re: Project: Teacup Firmware November 01, 2016 09:21AM |
Re: Project: Teacup Firmware November 01, 2016 11:03AM |
Re: Project: Teacup Firmware November 01, 2016 11:19AM |
youssefaly97
Hello, RRD Smart Controller support is still under development in teacup. There is a branch I created a while ago and I'm working on it a bit at a time, I'm sorry I'm slow at it, college takes my time away.
Re: Project: Teacup Firmware December 03, 2016 03:55AM |
Re: Project: Teacup Firmware December 23, 2016 11:05PM |
Re: Project: Teacup Firmware December 24, 2016 03:27AM |
Re: Project: Teacup Firmware December 24, 2016 06:33AM |
Wurstnase
Can you send me your config files and gcode. I would like to test it.
First thing I've seen. You enabled debug. This could slow down the code. For normal use, you should disable debug in debug.h. Just comment out #define DEBUG.
Re: Project: Teacup Firmware December 24, 2016 06:38AM |
Re: Project: Teacup Firmware December 25, 2016 06:48AM |
Re: Project: Teacup Firmware December 27, 2016 02:11AM |
Wurstnase
OK, just checked your config.
An Atmega can handle up to approx. 35k to 40k steps/s. Your E-Axis has 1,1540,000 steps/m. Your setup in S3D is 1,800 mm/min. This are 34,620 steps/s. Maybe too close on the limit. Also you could reduce max feedrate for E from 6000, which is too high, to a save 1500.
The old code uses the X-axis for a lot of calculations. This changed in the experiemental, and this could be the reason for your problem,
Re: Project: Teacup Firmware December 27, 2016 03:47AM |
git checkout -b zungmann_1 experimental~37and test your code again?
Re: Project: Teacup Firmware December 27, 2016 05:45AM |
Wurstnase
First of all, thanks for helping to improve Teacup.
In your config files you set the maximum feedrate to 6000. So your 180mm/s will decrease to 100mm/s any time.
As you are working with git. Can you please create a new local branch with
Re: Project: Teacup Firmware December 27, 2016 05:59AM |
zungmann
Yes, I am using git. I testing it now, still printing halfway and promising, so far so good.
Btw, how do I know what is the diff this experimental~37 from just experimental before?
git diff experimental experimental~37via gitk:
git checkout experimental gitk & git checkout experimental~37Hit F5, not shift-F5. Yellow circle is your current position. Everything above is new code, currently not active.
Re: Project: Teacup Firmware December 27, 2016 06:17AM |
Finish. And now printed perfectly. Thank you.Quote
zungmann
Wurstnase
Ah stupid me. Anyway I got decent 150 mm/s since now changed it to 9000.
Re: Project: Teacup Firmware December 27, 2016 07:47AM |
Re: Project: Teacup Firmware December 27, 2016 09:55AM |
Re: Project: Teacup Firmware January 11, 2017 01:34AM |
zungmann
Wurstnase
Thanks for testing. This is an experimental branch and needs testing. Can I ask you later to test this again?
No problem, I will be happy to test again. I like Teacup.
