Re: Project: FiveD on Arduino January 17, 2011 04:34PM |
It's hooked up to Step for each motor. I am now assuming that the signal is too fast for my steppers to follow. might try with fiddling around with feedrates a bit more until I get some kind of response. It must be something straightforward "slap on your forehead" kind of thing as the physical setup works with sample code AND it seems that some kind of signal is coming out of my Arduino..Quote
Triffid_Hunter
what signal did you hook the leds to? step, dir, enable, min, max?
I am using Ubuntu so I'll try MENDEL_TALK later today to see if I can figure out what's going on.Quote
Architect
I found that using the MENDEL_TALK command line tool from the func.sh scripts helped out when I started. I don't know if you are running your host on a *nix box or windows, but if you are on a UNIX variant then the func.sh was very helpful in my early testing.
Re: Project: FiveD on Arduino January 17, 2011 08:55PM |
Re: Project: FiveD on Arduino January 18, 2011 01:42AM |
Re: Project: FiveD on Arduino January 18, 2011 01:41PM |
Re: Project: FiveD on Arduino January 18, 2011 02:07PM |
Re: Project: FiveD on Arduino January 19, 2011 09:46PM |
Re: Project: FiveD on Arduino January 20, 2011 01:52AM |
Re: Project: FiveD on Arduino January 20, 2011 11:19AM |
Re: Project: FiveD on Arduino January 20, 2011 02:08PM |
Re: Project: FiveD on Arduino January 20, 2011 07:15PM |
Re: Project: FiveD on Arduino January 20, 2011 10:40PM |
Re: Project: FiveD on Arduino January 22, 2011 02:54PM |
petedee
Re: Project: FiveD on Arduino January 22, 2011 05:42PM |
Re: Project: FiveD on Arduino January 22, 2011 06:38PM |
Re: Project: FiveD on Arduino January 22, 2011 09:18PM |
G21 G1 X0 Y0 Z0 F2200 G1 X100 Y0 F2200 G1 X100.0 Y0 Z20.0 F2200 G1 X0 Y0 Z20 F2200 G1 X-10.4 Y0 F900.0 G1 X0 Y0 F2200 G1 X10.4 Y-57.4 F900.0 G1 X0 Y0 Z0 F2200 G1 X100 Y0 F2200 G1 X100.0 Y0 Z20.0 F2200
G21 G1 X0 Y0 Z0 F2200 G1 X100 Y0 F2200 G1 X100.0 Y0 Z20.0 F2200 G1 X0 Y0 Z20 F2200 G1 X-10.4 Y0 F900.0 G1 X0 Y0 F2200 G1 X10.4 Y-57.4 F900.0 G1 X0 Y0 Z0 F2200 G1 X100 Y0 F2200 G1 X100.0 Y0 Z20.0 F2200 G1 X0 Y0 Z20 F2200
Re: Project: FiveD on Arduino January 23, 2011 03:29AM |
AIO0_DDR &= ANALOG_MASK;
AIO0_DDR &= ~ANALOG_MASK;
petedee
Re: Project: FiveD on Arduino January 23, 2011 04:21AM |
petedee
Re: Project: FiveD on Arduino January 23, 2011 04:37AM |
Re: Project: FiveD on Arduino January 23, 2011 09:13AM |
Re: Project: FiveD on Arduino January 23, 2011 04:30PM |
Re: Project: FiveD on Arduino January 23, 2011 07:40PM |
Re: Project: FiveD on Arduino January 23, 2011 07:55PM |
Re: Project: FiveD on Arduino January 23, 2011 08:49PM |
Re: Project: FiveD on Arduino January 23, 2011 10:57PM |
Triffid_Hunter
sounds great, but I think it will be easier to manage with lots of config.h.boardulike- may make the Makefile a shade more complex but making slight alterations and creating new boards will be simpler.
Re: Project: FiveD on Arduino January 23, 2011 11:02PM |
Re: Project: FiveD on Arduino January 23, 2011 11:23PM |
Re: Project: FiveD on Arduino January 24, 2011 01:39AM |
commit c69cfb3551c5f4cca099897a11564da8f1fe9609 Author: - Date: Sun Jan 23 20:34:40 2011 -0600 Fixed for when GEN3 isn't defined. diff --git a/temp.c b/temp.c index c177038..83d636c 100644 --- a/temp.c +++ b/temp.c @@ -214,6 +214,7 @@ void temp_sensor_tick() { break #endif /* TEMP_PT100 */ + #ifdef GEN3 //If GEN3 isn't defined, these functions are undefined. #ifdef TEMP_INTERCOM case TT_INTERCOM: temp = get_read_cmd() << 2; @@ -224,7 +225,8 @@ void temp_sensor_tick() { break; #endif /* TEMP_INTERCOM */ - + #endif + #ifdef TEMP_DUMMY case TT_DUMMY: temp = temp_sensors_runtime.last_read_temp;
Re: Project: FiveD on Arduino January 24, 2011 02:23AM |
Re: Project: FiveD on Arduino January 24, 2011 05:17AM |
Re: Project: FiveD on Arduino January 24, 2011 10:12AM |
