Re: Project: Teacup Firmware March 31, 2011 09:38AM |
Re: Project: Teacup Firmware March 31, 2011 10:16AM |
Re: Project: Teacup Firmware March 31, 2011 10:23AM |
Re: Project: Teacup Firmware March 31, 2011 10:25AM |
Extruder stepper direction forwards speed 1rpm
[14:38:18
sending: N149 T0 G1 F1 *23
[14:38:18] sending: N150 T0 G1 E0.078349 F1 *101
[14:38:20] sending: N152 T0 G1 F1 *29
[14:38:20] sending: N153 T0 G1 E0.080016 F1 *104
[14:38:22] sending: N155 T0 G1 F1 *26
[14:38:22] sending: N156 T0 G1 E0.081683 F1 *102
Stepper direction reversed.
[14:38:31] sending: N165 T0 G1 F1 *25
[14:38:31] sending: N166 T0 G1 E0.080016 F1 *110
[14:38:32] sending: N168 T0 G1 F1 *20
[14:38:32] sending: N169 T0 G1 E0.078349 F1 *111
[14:38:32] sending: N171 T0 G1 F1 *28
[14:38:32] sending: N172 T0 G1 E0.076682 F1 *105
Re: Project: Teacup Firmware March 31, 2011 10:49AM |
Re: Project: Teacup Firmware March 31, 2011 12:18PM |
Re: Project: Teacup Firmware March 31, 2011 12:27PM |
Re: Project: Teacup Firmware March 31, 2011 12:35PM |
Re: Project: Teacup Firmware March 31, 2011 12:42PM |
Re: Project: Teacup Firmware March 31, 2011 01:10PM |
Re: Project: Teacup Firmware March 31, 2011 02:04PM |
Re: Project: Teacup Firmware March 31, 2011 02:28PM |
Re: Project: Teacup Firmware March 31, 2011 03:55PM |
Re: Project: Teacup Firmware March 31, 2011 04:07PM |
Re: Project: Teacup Firmware March 31, 2011 04:30PM |
Re: Project: Teacup Firmware March 31, 2011 05:24PM |
Re: Project: Teacup Firmware March 31, 2011 05:33PM |
Re: Project: Teacup Firmware March 31, 2011 06:49PM |
Re: Project: Teacup Firmware March 31, 2011 09:49PM |
Re: Project: Teacup Firmware March 31, 2011 10:39PM |
Re: Project: Teacup Firmware April 01, 2011 01:31AM |
Re: Project: Teacup Firmware April 01, 2011 02:12AM |
Re: Project: Teacup Firmware April 01, 2011 02:21AM |
Re: Project: Teacup Firmware April 01, 2011 03:40AM |
Did you miss the recent patches or are they so awfull its not worth commenting
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware April 01, 2011 04:25AM |
Re: Project: Teacup Firmware April 03, 2011 08:22AM |
#ifndef DEFINE_HEATER #define DEFINE_HEATER(...) #endif // name port pin pwm DEFINE_HEATER(extruder, DIO0) DEFINE_HEATER(bed, DIO1) // DEFINE_HEATER(fan, PORTB, PINB4, OCR0// DEFINE_HEATER(chamber, PORTD, PIND7, OCR2A) // DEFINE_HEATER(motor, PORTD, PIND6, OCR2
/// and now because the c preprocessor isn't as smart as it could be, /// uncomment the ones you've listed above and comment the rest. /// NOTE: these are used to enable various capability-specific chunks of code, you do NOT need to create new entries unless you are adding new capabilities elsewhere in the code! /// so if you list a bed above, uncomment HEATER_BED, but if you list a chamber you do NOT need to create HEATED_CHAMBER /// I have searched high and low for a way to make the preprocessor do this for us, but so far I have not found a way. #define HEATER_EXTRUDER HEATER_extruder #define HEATER_BED HEATER_bed // #define HEATER_FAN HEATER_fan
In file included from heater.c:34: config.h:297: error: lvalue required as unary '&' operand config.h:298: error: lvalue required as unary '&' operand
Re: Project: Teacup Firmware April 03, 2011 07:27PM |
Re: Project: Teacup Firmware April 03, 2011 08:49PM |
Re: Project: Teacup Firmware April 03, 2011 09:34PM |
Re: Project: Teacup Firmware April 03, 2011 09:50PM |
