Re: Project: Teacup Firmware June 02, 2011 06:29AM |
diff --git a/gcode_process.c b/gcode_process.c index 76a3c3c..4727388 100644 --- a/gcode_process.c +++ b/gcode_process.c @@ -469,6 +469,31 @@ void process_gcode_command() { power_off(); break; + // report endstop status + case 200: + #if defined(X_MIN_PIN) + sersendf_P(PSTR("x_min:%d "), x_min()); + #endif + #if defined(X_MAX_PIN) + sersendf_P(PSTR("x_max:%d "), x_max()); + #endif + #if defined(Y_MIN_PIN) + sersendf_P(PSTR("y_min:%d "), y_min()); + #endif + #if defined(Y_MAX_PIN) + sersendf_P(PSTR("y_max:%d "), y_max()); + #endif + #if defined(Z_MIN_PIN) + sersendf_P(PSTR("z_min:%d "), z_min()); + #endif + #if defined(Z_MAX_PIN) + sersendf_P(PSTR("z_max:%d "), z_max()); + #endif + #if !(defined(X_MIN_PIN) || defined(X_MAX_PIN) || defined(Y_MIN_PIN) || defined(Y + sersendf_P(PSTR("no endstops defined")); + #endif + break; + #ifdef DEBUG // M240- echo off case 240:M200 prints the status of the available endstops. I picked the command number pretty much at random, maybe there is a more sensible one.
Re: Project: Teacup Firmware June 02, 2011 06:40AM |
Re: Project: Teacup Firmware June 02, 2011 06:49AM |
Re: Project: Teacup Firmware June 02, 2011 06:53AM |
Re: Project: Teacup Firmware June 02, 2011 07:07AM |
iff --git a/gcode_process.c b/gcode_process.c index 76a3c3c..124c873 100644 --- a/gcode_process.c +++ b/gcode_process.c @@ -182,6 +182,21 @@ void process_gcode_command() { // G28 - go home case 28: + //? ==== G28: Move to Origin ==== + //? + //? Example: G28 + //? + //? This causes the RepRap machine to move back to its X, Y and Z zero endstops. + //? accelerating, so as to get there fast. But when it arrives it backs off by 1 + //? direction slowly, then moves back slowly to the stop. This ensures more accur + //? + //? If you add coordinates, then just the axes with coordinates specified will be + //? + //? G28 X0 Y72.3 + //? + //? will zero the X and Y axes, but not Z. The actual coordinate values are ignor + //? + queue_wait(); if (next_target.seen_X) {The //? lines can be easily filtered with a script, and you could probably set up a 3-way merge using git with the mediawiki version to avoid losing edits. How different are the firmware currently in development? Would it make sense to make a merged or a separate Wiki page? I'm still in the process of getting my first machine working, so I'm focussing on Teacup.
Re: Project: Teacup Firmware June 02, 2011 07:41AM |
Re: Project: Teacup Firmware June 02, 2011 09:12AM |
Re: Project: Teacup Firmware June 02, 2011 10:00AM |
Re: Project: Teacup Firmware June 02, 2011 10:27AM |
Re: Project: Teacup Firmware June 02, 2011 10:47AM |
Re: Project: Teacup Firmware June 02, 2011 12:11PM |
Re: Project: Teacup Firmware June 02, 2011 02:23PM |
Re: Project: Teacup Firmware June 02, 2011 06:27PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Project: Teacup Firmware June 02, 2011 08:08PM |
Re: Project: Teacup Firmware June 03, 2011 12:02PM |
Re: Project: Teacup Firmware June 03, 2011 07:17PM |
Re: Project: Teacup Firmware June 03, 2011 07:22PM |
Re: Project: Teacup Firmware June 04, 2011 03:18AM |
Now if only there were a way to slow down the really short infill so it doesn't shake my worktable...
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware June 04, 2011 03:54AM |
Re: Project: Teacup Firmware June 04, 2011 02:52PM |
prints interrupted June 04, 2011 03:38PM |
Re: prints interrupted June 04, 2011 08:18PM |
Re: prints interrupted June 04, 2011 08:19PM |
Re: prints interrupted June 04, 2011 10:32PM |
m114 ok X:0,Y:0,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22 g1 x0.1 ok m114 ok X:100,Y:0,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22 g1 y0.1 ok m114 ok X:100,Y:200,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22 g1 x0 ok m114 ok X:0,Y:200,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22 g1 x0.2 ok m114 ok X:200,Y:400,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22 g1 y0.2 ok m114 ok X:200,Y:800,Z:0,E:0,F:80 UMX:100,UMY:100,UMZ:1,UME:22and so on. The current_position.X affect the current_position.Y in a sort of exponential way. The X and Z axis are not affected by any other, and the Z axis don't affect Y.
case 114: //? ==== M114: Get Current Position ==== //? //? Example: M114 //? //? This causes the RepRap machine to report its current X, Y, Z and E coordinates to the host. //? //? For example, the machine returns a string such as: //? //? ok C: X:0.00 Y:0.00 Z:0.00 E:0.00 sersendf_P(PSTR("X:%ld,Y:%ld,Z:%ld,E:%ld,F:%ld\n"), ((int32_t)current_position.X) * ((int32_t) UM_PER_STEP_X), ((int32_t)current_position.Y) * ((int32_t) UM_PER_STEP_Y), ((int32_t)current_position.Z) * ((int32_t) UM_PER_STEP_Z), ((int32_t)current_position.E) * ((int32_t) UM_PER_STEP_E), current_position.F); sersendf_P(PSTR("UMX:%ld,UMY:%ld,UMZ:%ld,UME:%ld\n"), ((int32_t) UM_PER_STEP_X),((int32_t) UM_PER_STEP_Y), ((int32_t) UM_PER_STEP_Z), ((int32_t) UM_PER_STEP_E)); // newline is sent from gcode_parse after we return break;
Re: prints interrupted June 05, 2011 01:20AM |
Re: prints interrupted June 05, 2011 01:43AM |
start ok M114 ok X:0.000,Y:0.000,Z:0.000,E:0.000,F:50 X:0,Y:0,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1 G1 X0.1 ok M114 ok X:0.100,Y:0.000,Z:0.000,E:0.000,F:50 X:100,Y:0,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1 G1 Y0.1 ok M114 ok X:0.100,Y:0.100,Z:0.000,E:0.000,F:50 X:100,Y:100,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1 G1 X0 ok M114 ok X:0.000,Y:0.100,Z:0.000,E:0.000,F:50 X:0,Y:100,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1 G1 X0.2 ok M114 ok X:0.200,Y:0.100,Z:0.000,E:0.000,F:50 X:200,Y:100,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1 G1 Y0.2 ok M114 ok X:0.200,Y:0.200,Z:0.000,E:0.000,F:50 X:200,Y:200,Z:0,E:0,F:50 UMX:100,UMY:100,UMZ:1,UME:1
Re: prints interrupted June 05, 2011 04:33AM |
Re: prints interrupted June 05, 2011 04:38AM |
#define STEPS_PER_MM_X 10.0 #define STEPS_PER_MM_Y 10.0 #define STEPS_PER_MM_Z 1000.0 #include #define STEPS_PER_MM_E (3200.0 * 39.0 / 11.0 / 6.75 / M_PI)
Re: prints interrupted June 05, 2011 04:49AM |
Re: prints interrupted June 05, 2011 05:43AM |
case 114: //? ==== M114: Get Current Position ==== //? //? Example: M114 //? //? This causes the RepRap machine to report its current X, Y, Z and E coordinates to the host. //? //? For example, the machine returns a string such as: //? //? ok C: X:0.00 Y:0.00 Z:0.00 E:0.00 sersendf_P(PSTR("X:%lq,"), current_position.X * ((int32_t) UM_PER_STEP_X)); sersendf_P(PSTR("Y:%lq,"), current_position.Y * ((int32_t) UM_PER_STEP_Y)); sersendf_P(PSTR("Z:%lq,"), current_position.Z * ((int32_t) UM_PER_STEP_Z)); sersendf_P(PSTR("E:%lq,"), current_position.E * ((int32_t) UM_PER_STEP_E)); sersendf_P(PSTR("F:%ld"), current_position.F); // newline is sent from gcode_parse after we return break;
