Re: Project: Teacup Firmware July 24, 2011 01:51PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware August 07, 2011 01:32AM |
Re: Project: Teacup Firmware August 07, 2011 05:00AM |
Re: Project: Teacup Firmware August 07, 2011 03:37PM |
Re: Project: Teacup Firmware August 07, 2011 06:44PM |
Re: Project: Teacup Firmware August 07, 2011 07:27PM |
Re: Project: Teacup Firmware August 07, 2011 08:04PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Project: Teacup Firmware August 07, 2011 09:25PM |
Re: Project: Teacup Firmware August 08, 2011 12:16AM |
Re: Project: Teacup Firmware August 08, 2011 03:12AM |
And I have the habit of slicing a few hours a head of time then when it's time to print the filament is not always the same diameter as it was before using a few meters off the roll. So all and all I could see myself using it.
Re: Project: Teacup Firmware August 08, 2011 03:38AM |
Re: Project: Teacup Firmware August 08, 2011 05:22AM |
Re: Project: Teacup Firmware August 08, 2011 05:55AM |
Re: Project: Teacup Firmware August 10, 2011 09:33PM |
Re: Project: Teacup Firmware August 10, 2011 09:55PM |
Re: Project: Teacup Firmware August 10, 2011 09:59PM |
Re: Project: Teacup Firmware August 18, 2011 01:15PM |
Re: Project: Teacup Firmware August 18, 2011 11:04PM |
Re: Project: Teacup Firmware August 19, 2011 03:18AM |
Acceleration values should at least a few thousand, not 60
I have had to replace the
delay((uint32_t) (60.0 * 1000000.0 / STEPS_PER_MM_X / ((float) MAXIMUM_FEEDRATE_X)));
with a delay(150) which is what it evaluates to as having the formula in just produced a very high pitch noise.
Re: Project: Teacup Firmware August 19, 2011 10:24AM |
Re: Project: Teacup Firmware September 05, 2011 03:48PM |
Re: Project: Teacup Firmware September 08, 2011 07:29AM |
Fan doesnt work [...] and i think it should also be able to pwm different voltages on the output although cant find that exact spec of g-code in the wiki.
Also i am just curious if the multi-extruder setup is actually working? Because it sounds tempting enough for me to try for a next machine.
Should i use another branch, like master or stable?
And btw, TY for this firmware
Re: Project: Teacup Firmware September 08, 2011 07:37AM |
Problems with the extruder (just during printing) September 19, 2011 04:42PM |
Re: Problems with the extruder (just during printing) September 19, 2011 05:05PM |
Re: Problems with the extruder (just during printing) September 19, 2011 05:24PM |
Re: Project: Teacup Firmware September 20, 2011 07:20AM |
During printing neither MAXIMUM_FEEDRATE_XX nor SEARCH_FEEDRATE_XX seems to be used for speed control.
Re: Project: Teacup Firmware September 20, 2011 08:00AM |
Re: Project: Teacup Firmware September 20, 2011 08:57AM |
Re: Project: Teacup Firmware September 20, 2011 06:13PM |
