Re: Project: Teacup Firmware March 03, 2011 12:55PM |
Re: Project: Teacup Firmware March 03, 2011 04:15PM |
If you suggest some syntax, I could make libreprap (RepSnapper 2 already uses it) parse it and make the data easily usable by the host software.
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware March 03, 2011 05:13PM |
Re: Project: Teacup Firmware March 03, 2011 06:24PM |
Re: Project: Teacup Firmware March 03, 2011 11:38PM |
Re: Project: Teacup Firmware March 04, 2011 12:06AM |
Re: Project: Teacup Firmware March 04, 2011 12:08AM |
Re: Project: Teacup Firmware March 04, 2011 12:23AM |
Re: Project: Teacup Firmware March 04, 2011 04:47AM |
Re: Project: Teacup Firmware March 04, 2011 02:31PM |
Re: Project: Teacup Firmware March 04, 2011 09:45PM |
Re: Project: Teacup Firmware March 05, 2011 12:38AM |
Re: Project: Teacup Firmware March 05, 2011 02:57AM |
if (did_step) {
// we stepped, reset timeout
steptimeout = 0;
//if we could do anything at all, we're still running
//otherwise, must have finished
//HACK: if some crappy overflow happened - fix it here by making a zero into a large number TODO:Add upper bound
if(0 ==(dda->c >> 8)){
dda->c = 22117840;
Re: Project: Teacup Firmware March 05, 2011 08:15PM |
Re: Project: Teacup Firmware March 05, 2011 10:27PM |
Re: Project: Teacup Firmware March 06, 2011 06:13AM |
Re: Project: Teacup Firmware March 06, 2011 12:18PM |
Re: Project: Teacup Firmware March 06, 2011 05:52PM |
Re: Project: Teacup Firmware March 06, 2011 09:24PM |
Re: Project: Teacup Firmware March 06, 2011 09:44PM |
Re: Project: Teacup Firmware March 07, 2011 06:49AM |
Re: Project: Teacup Firmware March 07, 2011 08:16AM |
Tweaked direction for X and Y axes as they were gong the wrong way.
When they run they now run the right way.
Note I haven't got a lot of baseline to compare with yet so the above observations might not have been the changes that came down overnight.
git checkout master~20This sets you 20 commits back. If that solves the problem, try 10, then less. If the failure is still there, increase the number.
the unused XYZ MAX Limit inputs are linked to ground so that they are not floating.
Re: Project: Teacup Firmware March 07, 2011 10:51AM |
Re: Project: Teacup Firmware March 07, 2011 01:28PM |
Re: Project: Teacup Firmware March 08, 2011 12:09PM |
PWM Bang-Bang vs. "true" Bang-Bang March 08, 2011 03:11PM |
Re: Project: Teacup Firmware March 08, 2011 05:54PM |
Re: Project: Teacup Firmware March 08, 2011 07:28PM |
Btw, I think it's silly to have heaters on non-pwm pins, whose idea was that?
Nevertheless, all of the first three test boards worked fine, so the PR desaster for Gen7 introduction was inevitable.| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Project: Teacup Firmware March 08, 2011 10:40PM |
Re: Project: Teacup Firmware March 09, 2011 08:42AM |
