Batalov Sergey
How to measure distance to endstop? December 20, 2011 09:34AM |
Re: Project: Teacup Firmware December 21, 2011 04:37AM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Batalov Sergey
Re: How to measure distance to endstop? December 21, 2011 11:50AM |
Re: Project: Teacup Firmware December 22, 2011 04:36AM |
If so, should I introduce 3 new uint32 variables
z_counter and z_steps
Re: Project: Teacup Firmware December 22, 2011 02:44PM |
G28 M117XYZ ;reset internal coordinates G1X100Y100F8000 ;some move G28 ; go home M117 ; print coordinates G28 M117 G28 M117Here is a conversation:
> G28 < ok > M117XYZ ;reset internal coordinates < ok X:0,Y:0,Z:0 > > G1X100Y100F8000 ;some move < ok > > G28 ; go home < ok > M117 ; print coordinates < ok X:-10,Y:-23,Z:0 > G28 < ok > M117 < ok X:2,Y:-1,Z:0 > G28 < ok > M117 < ok X:0,Y:1,Z:0Increasing ENDSTOP_STEPS improves accuracy significantly.
dz_um = (dz_steps*((1000000L*100)/STEPS_PER_M_Z))/100;Maybe there is a better way?
next_target.target.F = MAXIMUM_FEEDRATE_X * 2L;I know that the correct feed rate will be computed later, but on my machine this causes (e.g.) G0X200Y200 to move (after short acceleration) very slowly with a strange sound. Moreover, using aforementioned M117, I can show that no step were loosed. Removing "*2L" solves the issue. I suspect, there is a overflow somewhere.
Re: Project: Teacup Firmware December 22, 2011 08:50PM |
In which units MAXIMUM_FEEDRATE_* should be, mm/min?
Re: Project: Teacup Firmware December 23, 2011 12:51AM |
But strange thing is that G1X200Y200F9000, that is a controlled move at maximum feed rate MAXIMUM_FEEDRATE_X=MAXIMUM_FEEDRATE_X=9000, works fine, but G0X200Y200 tries to move faster than 9000 and so does not work as expected. I thought G0 in this case should move at min(MAX_FEED_X, MAX_FEED_Y)=9000, but it moves faster.. Or maybe G1F9000 moves slower? Can we be sure that G0 moves not faster than the given maximum feed rate?|
Re: Project: Teacup Firmware December 23, 2011 05:02AM |
Re: Project: Teacup Firmware December 26, 2011 05:13PM |
Re: Project: Teacup Firmware December 27, 2011 04:14AM |
Re: Project: Teacup Firmware December 27, 2011 01:29PM |
Re: Project: Teacup Firmware January 08, 2012 02:31PM |
Re: Project: Teacup Firmware January 09, 2012 05:33AM |
Re: Project: Teacup Firmware January 09, 2012 03:28PM |
Re: Project: Teacup Firmware January 09, 2012 04:34PM |
Re: Project: Teacup Firmware January 11, 2012 04:24PM |
Re: Project: Teacup Firmware January 11, 2012 08:57PM |
Re: Project: Teacup Firmware January 12, 2012 10:08AM |
ifneq (,$(findstring usb,$(MCU_TARGET))) LDFLAGS += -Llufa_serial LIBS += -llufa_serial SUBDIRS += lufa_serial LIBDEPS += lufa_serial/liblufa_serial.a else SOURCES += serial.c endif
Re: Project: Teacup Firmware January 12, 2012 02:32PM |
ok FIRMWARE_NAME:Teacup FIRMWARE_URL:http%3A//github.com/triffid/Teacup_Firmware/ PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 TEMP_SENSOR_COUNT:2 HEATER_COUNT:2 ok ok X:0.763,Y:1.500,Z:2.237,E:0.000,F:50 ok X:1.000,Y:2.000,Z:3.000,E:0.000,F:50
Re: Project: Teacup Firmware January 15, 2012 02:22PM |
Re: Project: Teacup Firmware January 20, 2012 11:48AM |
Re: Project: Teacup Firmware January 21, 2012 08:30AM |
Re: Project: Teacup Firmware January 21, 2012 10:46AM |
I just remembered earlier warnings for microstepping on Z, which can cause problems generating enough interrupts. is that still a problem?
Re: Project: Teacup Firmware January 24, 2012 03:19AM |
Traumflug
Absolute E commands? Teacup stops working when this reaches 4300mm or something. Relative E commands work better.
Re: Project: Teacup Firmware January 24, 2012 06:02AM |
Re: Project: Teacup Firmware February 10, 2012 06:36AM |
Admin Registered: 15 years ago Posts: 2,569 |
Re: Project: Teacup Firmware February 10, 2012 02:20PM |
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Project: Teacup Firmware February 11, 2012 07:43AM |
Absolute extrusion means if a requested E move is to small for the extruder stepper to take it gets added to the next move
Re: Project: Teacup Firmware February 15, 2012 08:38PM |
Re: Project: Teacup Firmware February 29, 2012 11:22PM |
